Old 06-07-2009, 11:07 PM   #1
BlueJeep
BlueJeep's Avatar
AD S10 swap info
I have a 49 Chevy 3800 that is going to soon reside on an S10 frame. I'm almost done stripping my S10 and I wanted to share what I'm finding for those of you who may be considering this swap.
My S10 is a 95 extended cab with a 4.3 and 4L60, and I got it for free. Since my AD truck is a 3800 with a 9 foot bed, I figured to set it apart from the rest of the 3100 guys, I'd shorten the box to fit the extended cab S10's wheelbase and end up with a bed that's longer than a short box, and shorter than a long box. Shortening the frame isn't a problem for me since I'm a fab guy, but I did want it to be a little different.
I now believe that the newer body style trucks aren't good ones to use for the swap. First off, my frame is boxed back to the rear spring hangars, so shortening it to long-box specs isn't as easy (if that's what I wanted to do). Second, the brake pedal isn't removeable as an assembly, as it is on the older ones so bolting it into the AD isn't do-able. Third, the steering column is big and rectangular looking, and wouldn't fit the old truck very well. Fourth, 4 wheel ABS adds a lot of complexity to both the wiring and the plumbing. Fifth, the driveshaft has CV joints on the front and rear of it, so the rear axle has a flange vs. the yoke that's on my 4wd rear axle (I'm an axle guy too so this isn't a problem for me, but it could be for some folks).
So, since it was free I'm moving forward with it. I plan to use the S10 wiring harness as well since this truck had no options (no A/C, PW, PL, Cruise, etc.) so the harness isn't as complicated as it could have been. I have a buddy who's parting out a 90 S10 so fortunately I should be able to get the parts I need from him...but it would have been nice to use everything off the same truck.
This is mainly an FYI for guys looking to do a similar swap. My advice would be to seek an older S10 to use as the donor, so you could use more parts from it.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 06-08-2009, 12:32 AM   #2
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Re: AD S10 swap info
That is some good info. Thanks for sharing.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
Old 06-08-2009, 09:41 AM   #3
kulturekat
kulturekat's Avatar
i was planning on doing the swap and i located a full frame with 4x4 mainly for the rear end and kind of thought i could make the rest of it work. i have a 3600 so it has a long bed. so when i got the frame home i thought it had looked funny. so got the tape out and come to find out its not a long bed s10 afterall in fact not even a truck at all its a blazer and the front is is just too difficult to make work for what im doing so all im using off the whole frame in the 4x4 rear. so i know what youre going through i thought about stretching it through the senter but after all that effort itd be best to just get the correct frame. PLEASE KEEP US UPDATED ON YOUR PROGRESS
1969 c-10- daily driver(sold)
1950 chevy 3600 current project
http://67-72chevytrucks.com/vboard/s...d.php?t=402562
1955 ford f-100
1968 ford mustang
1966 ford mustang
kulturekat is offline   Reply With Quote
Old 06-08-2009, 03:51 PM   #4
BlueJeep
BlueJeep's Avatar
I guess I should also add that the parking brake cables are different between the 95 S10 2wd rear axle, and the 94 S10 4wd rear axle I got for it. It's minor, and I can just swap the 2wd stuff over to the 4wd axle but it's probably worth noting.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
