Old 06-08-2009, 09:13 AM   #1
BIGANTS83BLZR
**4wd to bagged 2wd blazer ***
I have been wanting to do this for years, but just could'nt find a good project truck untill 2wks ago. found it on a local craigs list search for $200. (no motor/trans/t-case) . So my plans for this blazer are..... converting it to 2wd bagging it, I'm seriously thinking about running it with 15" ralley wheels! wide lo profile tires....I dont know. ( i have 22's if I dont like it).so as I work on her, I will try my best to post pictures that nite.
BIGANTS83BLZR is offline   Reply With Quote
Old 06-08-2009, 09:24 AM   #2
BIGANTS83BLZR
Re: **4wd to bagged 2wd blazer ***
few more pictures of day 1,......... if I dont like the rally wheels, the wheels on my 67 will go on, just need to notch the rear for the 22"s.
Old 06-08-2009, 11:19 AM   #3
menace121978
menace121978's Avatar
nice job man! good find on the blaze. thats what my next build is gonna be... subscribing.
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 06-08-2009, 01:22 PM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
the blazer looks solid
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 06-08-2009, 02:59 PM   #5
tvblazer78
Low & Fast!
tvblazer78's Avatar
Keep us posted..
tvblazer78 is offline   Reply With Quote
Old 06-08-2009, 04:13 PM   #6
rcfatcat
rcfatcat's Avatar
sweet find i think it would be pretty cool to see the gm rally wheels on a lowered blazer keep us posted
78 k5 offroad project
350 sm465 60/14 np205
boatside, dovenose
rcfatcat is offline   Reply With Quote
Old 06-09-2009, 12:29 AM   #7
BIGANTS83BLZR
Re: **4wd to bagged 2wd blazer *** up date #1
Only had a couple of hours to work on the blazer today,but @ work today I had an idea!!! since the 67 is on hold for now and a long way from being anywhere close road worthy, why dont I borrow the front suspension from it?. it already has air bags hooked up, belltech 3" drop spindles, 6 lug CCP rotors, new bearings, channeled front x-member, notched driver side upper control arm. why not!.so I hooked it all up and just for kicks I put on the 20's and a fender.....I think I'm gana run the 20's up front and 22's on the rear. I'm even thinking bout keeping the same color combo...what do you think? so here are a few pictures of what went down today, tomorrow I plan on taking out the rear axle and messure things up for the 3-link.
Old 06-09-2009, 12:33 AM   #8
flamingbig10
6.0 powered square
man you work fast looking good
Aaron
Old 06-09-2009, 06:42 AM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Wow... what a change!
This is going to get interesting...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-09-2009, 10:10 AM   #10
menace121978
i was thinking the same thing! you dont mess around. she's already looking sick!
"Dennis the Menace"
Old 06-09-2009, 10:32 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
I think your headed in the direction I prefer. Keep the progress reports rolling in...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-09-2009, 10:47 AM   #12
jdurant
Definitely keep the paint scheme. There are a bunch of us out here that dig the two tone factory paint schemes. And I think you've got one of the best combos. I had a buddy with a real clean 4x4 Blaze with that color combo back in the day. It really played a part of solidifying my love for square bodies.
--I'm gonna send you a pm--
Joseph
87 Turbo Buick
92 5.0 Mustang coupe
87 GMC Sierra SWB
82 Chevy K5 Blazer 2wd
jdurant is offline   Reply With Quote
Old 06-10-2009, 12:56 AM   #13
BIGANTS83BLZR
Re: **4wd to bagged 2wd blazer *** up date#2
Again didnt get much time in the man room today,( had to take my son racing), well today I took out the rear end and messured up the frame for my notch and 3-link, I wanted to mock up the rear wheel so I could see if the factory rear wheel well would fit= NO. looks like trailer fenders will get fabed in. this set in another question, my 22's are 10" wide, the factory rear end mesures from hub face to hub face 5ft 5inch.... will that be too long? I'll have to check. I did discover that the blazer has a thick lip (about 1 1/2 ) on the inside of each rear quarter panel,maybe just a little trim will clear fine?? so anyway I set a 22" in the rear to just see what it will look like, because of that thick lip and rear wheel well, the rear is held up 1 3/4", once that is change out I think she will sit perfect.
Old 06-10-2009, 09:34 AM   #14
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sit's good! And I think you will need to trim the inner to make it work.
Old 06-10-2009, 10:27 AM   #15
jdurant
Yeah, I mocked mine up with 20s that are tucked more than I want and I'm still gonna have to trim, so I know you are going to. I hope you take good pics of what you do there, so I can take notes.
It's looking really good though.
Joseph
87 Turbo Buick
87 GMC Sierra SWB
Old 06-12-2009, 12:11 AM   #16
BIGANTS83BLZR
Re: **4wd to bagged 2wd blazer *** updat #3
did all my cutting and triming today, I got that extra 1 3/4" of rear drop, now that I have done that, I can cure that narrow rear axle problem these trucks have. I swapped all the 4x4 axles for a ford 9" that messured 66" long, it's the perfect length for my rear wheels. the only bummer bout today is that I had to remove the center mount when i cut out the floor. soon as I get my rear axle tomorrow I'll messure up the rear for my notch, keeping my fingers crossed that it's not too big so I could keep my rear seat. I'm also getting the trailer fenders tomorrow. a friend came by to check my progress, when I explaned why I'm triming the rear fenders for an extra 1 3/4" drop..... he said I was KRAZY (he's also a farmer with a lifted 3/4ton ford...TTTTT) anyway , till tomorrow guys
Old 06-16-2009, 03:05 PM   #17
lownfast
Gettinlow & Goinfast
looks great man, and i hate to bring bad news but if you lay rocker on 22's you gonna have to lose the back seat..... i did
Protouring Texas built rides-
78' K5 bodied on 22's, 5.3/ 4L60E- sold-Bdydrptk5- http://67-72chevytrucks.com/vboard/s...d.php?t=358390
71' Chevelle #Bigbootyjudy 6.0 LSx, LS9 heads, Magnuson, T56 - http://ls1tech.com/forums/conversion...e-ly6-t56.html
70' Chevelle #EvilAnnie Lsx/4L80/S475 turbo-
85' C20 crew, 5.3/6L90/S475 turbo-
68' C10 5.3/4L60/Level 2 coil overs
Facebook- Protouringtexasdotcom
Instagram- @Protouringtexas
lownfast is offline   Reply With Quote
Old 06-16-2009, 03:19 PM   #18
tvblazer78
Low & Fast!
tvblazer78's Avatar
Sweet! And dose it rain at your place all the time. I think every pic you post it's raining.
Old 06-17-2009, 12:30 AM   #19
BIGANTS83BLZR
Sup guys, I havent been getting too much time on the blazer, I messured up the rear notches and looks like I only need 6 1/2" to clear my axle. had some made today at my friends fab shop, also got my trailing arms notched and bushing tubes welded to them, since I'm not going to lay rocker I think the notches will be ok to keep the seat. anyway I will post pictures soon as my new cord for my camera comes in, DAM DOGS!!!!
Old 06-26-2009, 09:28 AM   #20
OARNGESI
OARNGESI's Avatar
Looks great
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 06-27-2009, 08:06 AM   #21
Mello Mel
African-American Shaolin Monk
TTT anymore word on this project ? It's not to often you get to see well done blazers like this and it sits sooooo perfect. I'm really interested in what you did to keep the back seat.
Mello Mel is offline   Reply With Quote
Old 06-27-2009, 09:27 AM   #22
BIGANTS83BLZR
Mello Mel. the only thing I did was had a 6" notch made from 2x3 square tube. 6" was all I needed to clear my axle. the upper bag bracket will mount to the frame and the lower will mount on the lower trailing arm. so keeping the seat will only require raising the cut out section of the floor 2 3/4", oh bout the seat, it wont be the original one,I took the rear seat from a 2000 jeep wrangler, it's just as wide but a little lower, the foam is not as thick as the blazer seat by about 1 1/2" so in all I should only raising the seat 1 1/4".******* I HAVE LOTS OF PICURES TO POST ONCE MY CORD FOR THE CAMARA COMES IN %^&*%$$(&$!@#$%^ BAD DOGGY!!!!!!!!!
Old 06-27-2009, 01:21 PM   #23
ndametz32
Fire Truck
ndametz32's Avatar
Looks sweet man! Keep it up
-Nick
'83 Chevrolet Silverado Stepside
http://67-72chevytrucks.com/vboard/s...d.php?t=349394
ndametz32 is offline   Reply With Quote
Old 06-27-2009, 01:35 PM   #24
Mello Mel
Thanks, that was exactly what i needed to know, and the lower profile of the jeep seat should really go well overall. can't wait to see the pics !!!!!!!
Old 07-13-2009, 02:02 AM   #25
BLOWN73
whats cool about your blazer is, if you ever move to cali...no smog
BLOWN73 is offline   Reply With Quote
