06-09-2009, 03:44 PM | #1 |
Front End Question
Are the spindles and hubs from a six lug, '69, C10 interchangeable with a C20 same year?
Thanks.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus! Last edited by Zonaman; 06-09-2009 at 03:45 PM. |
06-09-2009, 04:23 PM | #2 |
Watch out for your cornhole !
Re: Front End Question
Not without changing the ball joints too.
06-09-2009, 04:48 PM | #3 |
Never Ending Projects
I thought the lower arms were different. The ball joint is larger in diameter and won't fit into a 1/2 ton arm.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
06-09-2009, 05:03 PM | #4 | |
Just Not Low Enough!
why not go disc though?
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
06-09-2009, 05:27 PM | #5 |
Other way around 1/2 and 3/4 ton A-arms are the same, the LOWER BALL JOINT is bigger (the shaft, not the part that presses into the A-arm) on the 3/4ton, thus if going to 3/4 ton spindle, use the 1/2 ton A-arms and swap the lower BJ to 3/4 tons and you are golden! I second the why not go discs!?
06-09-2009, 05:48 PM | #6 | |
