Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-09-2009, 06:06 PM   #1
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
ford 9 inch swap
im thinking about a nine inch swap onto my stock trailing arms
im sure i can find a housing pretty easy
i can get a center section with richmond 4.11 gears (would change to 3.73s)
a mini spool and new bearings for $325
i would get new housing ends and perches
i think on an episode of musclecar they used a plate that bolts where the
centersection goes to show the center of the housing (since ford is offset)
im looking to fit a 12 inch wide wheel
im wondering where i cand find the plate and perches
and would it be worth it to do this swap
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 06-09-2009, 11:42 PM   #2
Captainfab
60-66 Nut
Re: ford 9 inch swap
I made my own plate with a mark for the center of the pinion. All you need to do is take some measurements off of the third member. Do you have all the necessary alignment tools and fixtures to narrow a housing?
I believe CPP and Early Classic sell the perches.
Old 06-10-2009, 01:16 PM   #3
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
no this is what i was going off of
http://www.crankshaftcoalition.com/w...wing_a_rearend
Gage
Old 06-10-2009, 11:07 PM   #4
Captainfab
60-66 Nut
OK.......they did use an alingment tool/jig to maintain a certain amount of alignment. How do you plan to keep the housing ends in alignment with the center section?
Old 06-11-2009, 06:58 PM   #5
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
how did you do it
Gage
Old 06-11-2009, 11:09 PM   #6
Captainfab
60-66 Nut
Originally Posted by jgh64pkup View Post
how did you do it
I have the alignment jig (the rod and the bushings shown in your link) to keep everything in line. Even with that, technically the housing should be straightened, but I've run them without straightening without issues.
You can also shorten your current 12 bolt, add different style housing ends, and install aftermarket axles, just as you can to a 9 inch. The 12 bolts will handle a lot of abuse, especially with upgraded parts. The 12 bolt has a 8.875 dia ring gear, so it's only .125 smaller than a 9 inch.
Old 06-12-2009, 12:38 AM   #7
ripdog28
ripdog28's Avatar
If i am reading you right, you need a housing. You do not need a lot of tools. Check out my build. I bought a housing for about $350 new from Currie enterprise. Shortened and all. total of over $3k into it all but i have alloy axles and almost $1700 center section. Just go online to currie and tell them what you want. make sure you get your measurments before ordering.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 06-12-2009, 03:59 PM   #8
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
that would be perfect and i wouldn't have to buy the tool to narrow it with
im pretty sure i have some 28 spline ford 9 in axles i could have narrowed and use until i get the mosers
and i have a single trac center section with 325 gears also 28 spline
Gage
