Old 06-10-2009, 01:03 AM   #1
84 400
Sb 400 club
84 400's Avatar
Lift kit questions
So I got a buddy who wants to trade me a lift kit for swapping his bed. So I want to mesue first and ,make sure it is a 4 inch. Can I just measure the rear block? It should be what 4 inches high right?? Also will I notice a diffrance? My truck is a Heavy half/ Big ten model with the heavy duty front/ rear springs. It sits pretty high stock.
I know a novice question but I am new to the whole lifting thing.
Oh and I will be ditching the rear blocks for a shackle flip
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 06-10-2009, 01:40 AM   #2
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: Lift kit questions
If you are ditching the rear block, what does it matter how tall it is? I think the shackle flip will give you more than 4", but I could be wrong.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 06-10-2009, 02:14 AM   #3
dammitmitchell
the pollock
dammitmitchell's Avatar
you should have this moved to the 4x4 forums...
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-10-2009, 03:23 AM   #4
84 400
Sb 400 club
84 400's Avatar
It matters because this would help me determine how big the lift kit is. The front has lift leaf springs so I would think measuring the rear lifting block would tell me how much the entire kit is. It is installed on a truck currently and I want to make sure it is 4 inch before taking it apart.
The shackle flip is this in case anyone is curious.
http://www.offroaddesign.com/catalog/shacklekit.htm
1985 C10 LWB Sold
Old 06-10-2009, 08:54 AM   #5
tgh117
Crazy
tgh117's Avatar
Measuring the block would be a good starting point. Although, if there is a chance that the other truck had a spring swap at the same time? If 3/4 or 1 ton springs were swapped on, it could be taller then 4" Take a look at my truck in the picture for example. I am basically in the same deal as you, got a lift that I didn't know anything about, and just put it on. it still has the 4" blocks in the rear at the moment, so I could check the height and rake, but at the moment, I believe the rear is about an inch higher then I woud realistically like it, which makes me believe the springs I got could differ from a 1/2 ton. So my moral of the story is start with the measurement, but there is a chance its different. You may want to take the rear springs from the other truck just in case.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 06-10-2009, 09:46 AM   #6
babyJay
Arrived on a Pale Horse
babyJay's Avatar
That was some good advice, TGH, and your truck does have some rake to it.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-10-2009, 08:32 PM   #7
tgh117
Crazy
tgh117's Avatar
yea I know it does, more then I want I think... I may go with a 3" block to compensate, but that won't be decided for a little while. Have to tidy up a few things, and take of the interior, then I will get that taken care of for the final details. I also need some sort of mudflaps to keep the paint on the bottom of the truck to.
