Old 06-10-2009, 04:16 PM   #1
Conundrum
Conundrum's Avatar
Another trans swap question
I am hoping to get around to swapping a 350/700R4 combo from my 86 burb donor into my 74 SWB within the next few weeks.
I am wondering if anyone can tell me what all wires I would need to keep in order to use the stock computer to control the trans functions? Got a diagram maybe?
I don't really have the money to buy anything from the aftermarket for it at this time, and I need to get this thing going.
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 06-12-2009, 04:23 PM   #2
Conundrum
Conundrum's Avatar
Re: Another trans swap question
Do I just need to keep the wires that run to the trans, plus the power and ground wires? Will that work? Or should I just wait until I can afford an aftermarket solution?
Old 06-12-2009, 04:31 PM   #3
menace121978
menace121978's Avatar
subscribing to this... anyone??
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 06-13-2009, 06:59 AM   #4
grinch4om
dang its hot
grinch4om's Avatar
aftermarket is the best for this application..TCI makes a good one
grinch4om is offline   Reply With Quote
Old 06-13-2009, 11:38 AM   #5
rfmaster
rfmaster's Avatar
There are about half a dozen different 700R4 internal harness configurations. The TCI harness simplifies it and make it easy to use for a non ECM configuration. Take a look at TCI documentation
http://www.tciauto.com/Products/Inst...76600_inst.htm
Internal trany wiring is straight forward, but you need a replacement switch (GM part number is provided) and can be easily duplicated.
Externally a brake switch and a vacuum switch can be wired for TC lock up function.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 06-15-2009, 03:49 PM   #6
Conundrum
Conundrum's Avatar
Thanks for the link.
Another reason I asked if I could do it with the stock ecm was that the guy I got the donor vehicle from is a friend of mine and said the trans only has about 3000mi on it, and I don't really want to pull the pan off.
