06-10-2009, 08:25 PM | #1 |
stock trailing arms
How strong are the stock trailing arms. My intention is to run stock trailing arms and coilovers outside the frame rails. I would like to build and engine that puts out 450 horse and around 500 foot pounds of torque. Will I have problems? What do you guys run?
06-10-2009, 08:31 PM | #2 |
Re: stock trailing arms
I had a pretty healthy 385 stoker on my stock trailing arms and havent ahd any problems!!! If you are haveing bad thoughts about it just get some metal and box them in!!!!
1968 GMC Rebuilding Stage 2001 Camaro SS SOLD |
06-10-2009, 09:55 PM | #3 |
its all about the +6 inches
if it is typical north eastern trailing arms... I'd be scared.
If they are clean trailing arms in good shape, then you'll be fine. |
06-11-2009, 12:25 AM | #4 |
I've got 383 stroker pushing 630TQ/620HP running stock trailing arms with zero concerns, .
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-11-2009, 12:59 AM | #5 |
my trailing arms were in good shape, but I welded a fat bead along the entire length of the arms on both sides just for good measure.
06-11-2009, 01:03 AM | #6 |
i'm gonna have to agrue with every one. it depends on what your gonna do with the truck. if ya drive if on the street just smokin the tires and not hookin, your probably never have any problem with them. if you got to the track and get it hook theres a god chanve youll bend them. i've bent them at the track racing. i leave at 5200rpm droppin the clutch, mucnie 4spd. based on the et's i'd said im somewhere in the 450hp range. i went and boxed the end where the axle bolts on and welded the two channels together. no problem since then. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's Last edited by 71chevytruckguy; 06-11-2009 at 01:05 AM. |
06-11-2009, 08:53 AM | #7 |
Prestige Worldwide
Go look under the rear of any Nascar Division car or truck and tell us what you see.....
06-11-2009, 09:12 AM | #8 |
Junior Member
My son was running rusty stock trailing arms in his short bed that has a slightly modified 454 in it.
One day he was play as he often does and destroyed one of them. I had a set of near rust free trailing arms out of a 67 3/4 ton and he put them in and has not had a problem. The ones from the 3/4 ton seem to be built a little stronger. Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-11-2009, 09:21 AM | #9 |
I just bought nice trailing arms from Arizona with no rust. My motor is kind of weak now. I'll leave the arms alone since all my driving is street. But when I do the new motor, I'll beef them up. Still my driving will be 99.9% street. I'd like to go to the racetrack, but I've had the truck 5 years and haven't gone yet. So, I assume not much will change. Thanks for all of your input. Has anyone used the CPP trailing arm reinforcement kit?
06-12-2009, 01:02 AM | #10 |
lol when my camera decideds to work again, I got some pics for ya'll, mine are rotted beyond belief
06-12-2009, 06:17 PM | #11 |
Couldn't find my link, but there is a couple of sites in the NC area that sell take off parts from NASCAR. They use truck trailing arms and they are a lot
stronger than the stock arms. Price's use to be reasonable too. Maybe some one else will chime in with a link. |
