Old 06-11-2009, 02:26 PM   #176
SUB602
SUB602's Avatar
Re: Here is a "Not Your Typical" 4wd Blazer build
I can just sit here and stare at your welds all day. Very nice work Bud!!!
www.SlammersKustoms.com
98 GMC K1500 Suburban
75 K-5 SB350/TH350/NP205
74 K-5 Convert to 2wd and bag her
Authorized dealer for the Dropmember, Built by PorterBuilt Street Rods
SUB602 is offline   Reply With Quote
Old 06-11-2009, 05:03 PM   #177
sandking
.....I am working on it.....
sandking's Avatar
Thanks!!!
View my build thread HERE
sandking is offline   Reply With Quote
Old 06-13-2009, 01:12 PM   #178
Mordachai
Fat Fendered Fleetside
Mordachai's Avatar
man, what an awesome project.
I must have been under a rock or bridge to miss this one...
71 GMC lwb
56 Big window swb
93 GMC Sonoma (dd)
radiused fiberglass fender project for 67-72
Mordachai is offline   Reply With Quote
Old 06-13-2009, 01:49 PM   #179
texanidiot25
Eat My Rust
texanidiot25's Avatar
I can't wait to see this one done
texanidiot25 is offline   Reply With Quote
Old 06-13-2009, 04:05 PM   #180
sandking
sandking's Avatar
Thanks guys.
Stay tuned, working on the engine, trans and t-case install today. I will post some pics later.......
Old 06-13-2009, 09:54 PM   #181
sandking
sandking's Avatar
Got some work done today. I was able to use the stock '07 Chevy Tahoe motor mounts and the stock Blazer cross member to set the engine in place. A little fab work was worth the saving of buying some conversion engine mounts. I just need to add some plating to the cross member and the tube mounts then it's done. The Blazer stock trans/t-case cross member is also going to be used. The trans sits about 2" higher then the original mount due to the engine configuration and the extra oil pan clearence from the front pumpkin, but a little trimming with the plasma and it clears. I will patch the floor later. Here are some pics of todays progress, I will snap some pics of the trans mounts tomorrow.....
Old 06-13-2009, 09:57 PM   #182
sandking
sandking's Avatar
More
Old 06-13-2009, 10:01 PM   #183
sandking
sandking's Avatar
Last few
Old 06-13-2009, 11:34 PM   #184
hgs_notes
GEARHEAD
hgs_notes's Avatar
Looks like a good fit. Couple questions, is there any concern with having the engine and tranny higher, raising the center of gravity? Also, was wondering if the front frame rail crossmember was going to be strengthened. I've seen someone replace it with a stronger tubular support. I know you have tubes across the top, I was wondering if the bottom needed extra strength to keep it from spreading or even colapsing inward during high speed turning.
I really like this build. Makes me wish I still lived out west.
hgs_notes is offline   Reply With Quote
Old 06-14-2009, 12:34 AM   #185
sandking
sandking's Avatar
I thought about the higher center of gravity, but I dont think this small amount will be notice much. I also have all the weight of the interior cage that does not help with the weight up high. One thing to consider is the ride height will be quite lower then most trucks with 35" tires. Only a couple of inches higher then stock.
The cross member will be stengthened quite a bit. I was going to make my own cross member, but I thought since I have this one, I will try it. If I dont like the finished part, I will build my own, but I am confident this will be plenty strong by the time I am done.
Old 06-14-2009, 05:40 PM   #186
onetonk5
Cereal Killer
onetonk5's Avatar
So whats the deal with the glass? fenders and bedsides? rig looks great
If I dont do it....somebody else will.
onetonk5 is offline   Reply With Quote
Old 06-14-2009, 05:59 PM   #187
sandking
sandking's Avatar
Untill I can find some decent ones, I am going to modify these to clear the tires.
Old 06-14-2009, 06:30 PM   #188
onetonk5
Cereal Killer
onetonk5's Avatar
No I meant the flared bedsides and raised and flared front fenders. I found the guy on a class 3 site that has all the hickey rides. Any idea if he is selling fenders or bedsides? Did you ever think about ttb or even 2x4 and beams? I love the look of a long beam droped way down.
Old 06-15-2009, 08:44 PM   #189
sandking
sandking's Avatar
I understood. I am just using the stock front and rear and modifying them to clear.
Not a fan of the ttb, the in and out camber drives me nuts. For some people, they are great. To each his own I guess.
Old 06-19-2009, 08:54 PM   #190
sandking
sandking's Avatar
Qeustion for you suspension experts...
As you know, radius arms will bind in an articulating situation. Since I have these arms built, can I just "cut in" a small shock on the upper arm like my paint pic below? The shock could act like a sway control to some extent. Any thoughts?
Old 06-19-2009, 11:46 PM   #191
Captainfab
60-66 Nut
Very nice build and excellent fabwork......subscribing
Old 06-20-2009, 12:02 AM   #192
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
When I saw this thread pop up and looked at the first page, I couldn't figure out why you were building a 1,987 pt. roll cage. Now I know!
P.S. You might want to PM me so I can give you some pointers on making better welds!
prostreetC-10 is offline   Reply With Quote
Old 06-20-2009, 12:09 AM   #193
sandking
sandking's Avatar
Thanks!!
Old 06-20-2009, 12:13 AM   #194
sandking
sandking's Avatar
.......And the cage is not even done yet!!
I know, I know, my welds suck, but I am a rookie, what can I say
Old 06-21-2009, 12:38 PM   #195
sandking
sandking's Avatar
Not much since last update, but I got started on the brake line mock up. I swear, I think the big tubing is easier to work with then this litlle 3/16 stuff The brake lines will run inside the frame rails down the driver side. The fronts convert to a bulkhead 90* then to braided flex on the radius arm for the movement. The flex then goes back to hard line on the arm then back to flex to the caliper. I used banjo fitting on the caliper. Also, I never posted the pics of how I lowered my brake booster. I just simply turned the brackets over. A little cutting and welding and it was done.
I also threw the fenders on to see where the tires ended up since I pushed the axle forward some. A little trimming should take care of it. Dont worry, the fenders are not in the best shape, so cutting them will only shed one tear instead of two.
Old 06-21-2009, 12:43 PM   #196
sandking
sandking's Avatar
More.........
Old 06-21-2009, 12:46 PM   #197
sandking
sandking's Avatar
More......
Old 06-21-2009, 12:48 PM   #198
sandking
sandking's Avatar
Yes, I like to take pictures
Old 06-21-2009, 12:53 PM   #199
sandking
sandking's Avatar
More...
Old 06-21-2009, 12:57 PM   #200
sandking
sandking's Avatar
Last for now...
