Old 06-12-2009, 02:27 PM   #1
ggtsvnv
how to tell if a truck is an orgional 4WD?
Hi all,
I have found a 69 GMC 4WD truck for $500.00. It has some rust in the rockers and cab corners and a few bumps and bruises but the rest of the body seems ok. However I'm not sure if it was a 4WD from the factory, the bed and cab have no gap between them at the top which makes me wonder if the frame was switched or bent. Looking under it at the frame I cannot see any obvious bends in the frame so I was thinking maybe someone took the truck and put it on a different frame to make it a 4WD. It does have on the inside roof of the cab instructions for the 4WD shifter (which seemed like a strange place for it). the glove box door is not orgional and was wondering is there any other way to tell if it was a factory 4WD?
Thanks in advance
ggtsvnv is offline   Reply With Quote
Old 06-12-2009, 02:49 PM   #2
americanmusc1e
americanmusc1e's Avatar
Re: how to tell if a truck is an orgional 4WD?
post some pictures, that might help, we have a 4wd suburban and I think the 4wd information is on the visor
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 06-12-2009, 03:08 PM   #3
69GMCLonghorn
69GMCLonghorn's Avatar
Being a California boy spoiled by rust free vehicles, I say if it has ANY rust, forget it... In terms of the gap, again I'd say forget it. Unless you just plan to use it for parts, I'd never trust a truck like that, especially not in any kind of an actual 4WD situation.
However, it could be as simple as a cab to frame mount that has lost its rubber so it's sitting crooked. Lots of possibilities, many of them quite F-UGLY!!
69GMCLonghorn is offline   Reply With Quote
Old 06-12-2009, 06:17 PM   #4
sweet70beast
sweet70beast's Avatar
Not all of us are lucky enough to find rust free, dent free anything especially in farm country. These are trucks and they were built to be and were used.
Look at your vin # if it starts with a K it is an original 4by if its a C it was a 2wd. I doubt that someone would switch the vin while doing a frame swap but anything is possible. All the trucks that I have seen that have had frame swaps, the owner kept the 2wd vin plate on it.
Unless there are big problems 500 bucks is a good deal.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 06-12-2009, 06:28 PM   #5
69GMCLonghorn
Hey, I live in LA. There isn't a hell of a lot to brag about that fact... At least let me brag about being rust free!
Old 06-12-2009, 06:47 PM   #6
see ten
WTB this ad
see ten's Avatar
On Chevrolets, the Second symbol of the VIN will be a K, not the first. Also all factory 4x4s will have a high hump floor.
see ten is offline   Reply With Quote
Old 06-12-2009, 08:43 PM   #7
vectorit
What?
vectorit's Avatar
Hmmm my 68 K20 VIN starts with a K...
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-12-2009, 09:37 PM   #8
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Chevy VIN's had three letters in 72, otherwise there should only be two letters. BUT, this is a GMC, so it should only have two letters to start the VIN.
So VIN starting with K, and a high hump trans cover should prove it. If you can get a mirror and look under the cab on the drivers side on top of the frame rail, you might be able to see the VIN stamped into the frame to see if it matches the cab and title.
As far as the cab/box issue, look at the rear cab mounts. Probably shot.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 06-12-2009, 09:37 PM   #9
ggtsvnv
Thanks for the replies, I will call the seller and have him check the VIN for me.
Old 06-12-2009, 10:26 PM   #10
That`s in`72.Chevys start with a C and GMCs start with a T.The second letter would be C or K,like the earlier year`s 1st digit.
