Moderator
![]() Join Date: May 2007
Factory Vacuum gauge
Was there a special vacuum line used from the factory for trucks with the vac gauge? It looks to me like a pre-formed hard line was used, just like the oil pressure line. When I pulled the gauge panel, there was no line attached to it. Does anyone have a pic, or know how the gauge was originally hooked up? Also, where on the engine was it connected to? I may be posting a WTB ad following the info I receive from this question....or I might go to Lowes and see if I can find a barb to thread onto the back of the gauge, and just run a rubber vacuum line. Thanks for any info.
member #16
![]() Join Date: Dec 1999
Re: Factory Vacuum gauge
I am sure you are right about GM using a hard tubing. I just wanted quick and simple ,so I used 1/8" plastic tubing to the carb.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Scott it was a hard line from the factory on the big trucks and the setup was similar in construction to the modulator valve line for the trans- a rubber line used to connect at a vac source on the engine. You could get some of the copper tubing sold for oil pressure line and a couple of fittings with ferrals and be good to go I would think or you could use regular vac. line and accomplish the same thing.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle Last edited by 71 super; 06-14-2009 at 12:02 AM. |
