06-15-2009, 12:57 PM | #1 |
Asks alot of questions
'69 rear end 5 bolt conversion ?'s
I am putting disc brakes up front on my '69, 5 lug system from a newer truck. In order to swap out to 5 lug in the rear, will I have to change the rear end or can I just change the axle rods? My truck has rear coil suspension not leaf.
MY STABLE: '66 C10 LWB turning it into a shortbed stepside '77 LWB (my daily driver).....oh its a FORD ahhhhh! '07 MAZDA 3 (the wife's ride) |
06-15-2009, 01:08 PM | #2 |
Re: '69 rear end 5 bolt conversion ?'s
some of the experts may correct me here if im wrong, but the 67-70 axle housings are narrower than 71 and up. best bet is to find a 71-72 coil rear to swap. im not sure here either ,but maybe just get some 6 lug rotors from one of the board vendors???
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
06-15-2009, 01:19 PM | #3 |
Thanks for the help. Id rather go five lug all around. I had heard myself that the axles on the older trucks were wider.....anyone know how hard its gonna be to find a 71-72 coil spring rear?
06-15-2009, 01:36 PM | #4 |
i think it's Early Classic that offers axles in 5 x 5" pattern that fit your housing. You may also check with our board vendors and see if they are a re-seller for ECE products.
06-15-2009, 02:02 PM | #5 |
Thanks for the tip
06-15-2009, 06:05 PM | #6 |
or you can do what i did. take your axles out, take them to a machine shop and have them redrilled for 5 lug and your center hub shaved down. I think it only cost me $60. real cheap, real easy
