Old 06-15-2009, 09:20 PM   #1
postman
i need help with my 1971 chevy cheyenne
hi i am having trouble with my 1971 chevy cheyenne longbed, it runs good but then stops and have trouble turning it back on without putting a bit ot gas directly on the carburator i already changed the fuel pump and new filters but keeps doing the same thing , what could it be
postman is offline   Reply With Quote
Old 06-15-2009, 09:23 PM   #2
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: i need help with my 1971 chevy cheyenne
Possibly timing too far advanced?
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 06-15-2009, 09:27 PM   #3
Shyguy
Junior Member
Shyguy's Avatar
It could be that one of the rubber hoses in the fuel line has holes in it or is collapsing.
Also the filter/sock in the tank could be plugged.
The float in the carb could be sticking.
As you see it could be a number of things.
Hope this helps.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 06-15-2009, 09:31 PM   #4
The Big Green
Why would timing to far advanced run out of gas???
If you did the filter and pump, then maybe trash in the carb? If it's starts and runs good, like you stated, then timing is good. To far advanced and the starter will kick back, to retard and starter will drag.
The Big Green is offline   Reply With Quote
Old 06-15-2009, 09:36 PM   #5
The Big Green
Shyguy is right! He got more into it than I did. I would clean the carb first though and then look into the lines. SOME carbs have a filter in them, few don't. If there's gas in the filter then don't bother with the lines and go for the carb first.
Old 06-15-2009, 09:51 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the problem will be in the carb, not fuel delivery.
if there was a restriction or blockage, it'd act stupid when rollin down the freeway, not sittin in the driveway.
What kind of carb is on it? Edelbrock?
Old 06-15-2009, 10:08 PM   #7
crm318
Alright Alright Alright
crm318's Avatar
I had the same problem on a 71 cutlass i used to have. It turned out that there was a line of custy crumbling hose that was sucking air. I changed it out with new hose and the problem was solved.
1972 Cheyenne
Chevrolet red and white
357ci, Vortec heads,
GM Performance high rise intake,
Comp 268H .454/.454 218/218 110 LSA
Quadrajet carb, Flowtech headers, 2.25 40 series
HEI, Curve kit, TH 350, 3.07 gears
275/60/15s on 15x8 rallies
crm318 is offline   Reply With Quote
Old 06-15-2009, 10:31 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
All of this reminds me of a chronic problem I had with a motorhome back in the 80's that had dual exhausts.
It was doing the same thing as you describe. I tried everything with the fuel system and even checked out the ignition system.
It about drove me crazy, the engine would just die and in 10 minutes or so it would fire right back up and run ok for a long time.
We were on our way back to California in the town of Mohave when it did it. I crawled under it and found that it was real hot near the fuel line where a filter was. I finally figured that the pressure drop across the filter and the heat was causing a vapor lock. I wrapped a wet towel around the fuel filter and drove home without another vapor lock.
I replaced the fuel line with a 3/8" metal line and routed it away from the exhaust. I never had a problem again.
Danny
Old 06-15-2009, 10:41 PM   #9
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The same problem on my buddy's 57.The rubber fuel line from the tank to the metal line was sucking air.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 06-15-2009, 10:42 PM   #10
The Big Green
I traded a buddy a car for a little '91 350 S-10 a couple years ago. I couldn't make it home. It ran for a couple miles and died, and a few minutes I was gone again then it did it again. I noticed (2) 3/8 lines underneath the steering column, turns out that the one that was cutoff and he plugged it up. Thing is that what he plugged up was the gas tank breather line LOL. What it was doing was stucking the air from the tank and couldn't feed the carb. I don't see that as your problem but just a story. Never seen a old truck of these years being that air tight.
Old 06-15-2009, 11:34 PM   #11
Longhorn Man
i totally misread that.
i thought he said he had problems restarting it after stopping.
How long can you run it till it acts up?
