5.3 fuel line
"you can also use aliminum tube and an fittings. its easy to bend and cheap.
3/8 fuel line- http://www.jegs.com/i/JEGS/555/15100/10002/-1 compression fittings- http://www.jegs.com/i/Earl%26%23039%...65106/10002/-1 pay no attention to that 50 psi max bull stuff" It shows use for only 25PSI, can i use this safely? what have you used?
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 ****SOLD!!!!!**** 1965 GMC 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=294727 |
Re: 5.3 fuel line
I used my stock fuel line(hard line on frame) and used the hard tube adapters to -6AN to go to motor and fuel tank.
http://www.jegs.com/i/JEGS/555/100550/10002/-1
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
Re: 5.3 fuel line
I just plumbed mine using dorman hard plastic line and fittings, like new style vehicles. this is the first time I have used it, but seems to work pretty good.
Always wrenching!!
Re: 5.3 fuel line
I used factory gm plastic quick disconnects and high pressure rubber fuel line (goodyear).
here's a pic of the connection at the rails.... ![]() here's a pic of the line at the pumps.... ![]()
71 C-10 5.3L/4L60E 72 Camaro LS6/4L60E 06 Duramax 19 RZR XP4 turbo Dynamix 56 Belair 5.3/4L60E swap in progress |
Gearhead
Re: 5.3 fuel line
I used the Jeg's 3/8" aluminum hardline for my LT1 and I havent had any problems so far. I used the AN adapters to the stock quick disconnects on the engine. I run at least 40 psi at idle and Im sure 10 psi or more over that at WOT the Walboro pump will do up to 100 psi if unregulated so I am confident so far. Hope this helps....
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 Last edited by 6772owner; 06-17-2009 at 09:45 AM. Reason: pics |
Re: 5.3 fuel line
I used aluminum fuel lines, and -6 AN fittings. I have some braided stainless hose also to allow for engine movement as well as from the tank to the fuel filter/regulator. I used some QD fittings as well.
Re: 5.3 fuel line
Re: 5.3 fuel line
Where Did you get the factory quick disconnects?
Re: 5.3 fuel line
... And is that Fuel injection hose different from just regular fuel line?
Always wrenching!!
Re: 5.3 fuel line
I got the quick connects from the crashed vette. they are the fittings for the fuel filter. the hose is fuel injection hose, has a plastic liner instead. thin blue plastic surrounded by the black rubber. I used high pressure clamps also.
#11 | |
Re: 5.3 fuel line
Also, could i have a pic of your corvette regulator mounted to the frame?
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4 Work in Progress http://67-72chevytrucks.com/vboard/s...d.php?t=291482 ****SOLD!!!!!**** 1965 GMC 4X4 http://67-72chevytrucks.com/vboard/s...d.php?t=294727 Last edited by 72truckman; 06-18-2009 at 03:11 AM. |
Gearhead
Re: 5.3 fuel line
I bought the fuel injection hose clamps at Advance Auto Parts when I did mine, they are specific for this purpose and they have all the popular sizes.
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
#13 | |
Always wrenching!!
Re: 5.3 fuel line
I didn't use the vette regulator. I used a truck fuel rail that was regulated and had a built in return line........
