Old 06-17-2009, 03:18 PM   #1
onebad65c10
Gm for life.
onebad65c10's Avatar
Thumbs up Watts link install.
Installation of KP komponets Watts link in a 1965 Chevrolet C-10.
The truck this is being installed on is My 65 c10 that has been air bagged with firestone 2600's out back. The truck also features a Classic Performance bolt in c-notch that has been welded and smoothed.
This is a sight that I am sure many of you 60-72 owners are familiar with the stock two link with a panard bar.
Here is the kit laid out to check for all the parts. It is a nicely constructed piece that comes powder coated.
All the hardware is grade 8
First step was to install the center bell crank in to the rear pumpkin cage.
Next I had to remove the stock panard bar bracket by cutting the rivets and using an air hammer.
Next the cage was bolted to the rear differential using the supplied hardware.
Next the links were assembled and put in to test for articulation and placement of weld in plates.
The only welding was because I have the stock frame in the rear.
Here is a final install picture after the welds cool and ground down, and everything was undercoated.
This picture is at full lift.
This picture is full drop. Through the whole range of motion the rear end only moves about a quarter inch.
I don't know if I have posted a pic with the new wheels, so here it is. The are the full size 4 wheel drive Gm rallies and chrome center caps. I do have the trim rings on them now. The tires are 245/60/R15 Bf Goodrich Radial T/A.
onebad65c10 is offline   Reply With Quote
Old 06-17-2009, 05:31 PM   #2
shortbed70
shortbed70's Avatar
Re: Watts link install.
Do you have any problems with pumpkin hitting bed floor? I am also going to do 2600 in the rear on my 65
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 06-17-2009, 06:23 PM   #3
onebad65c10
Gm for life.
It did when it was first installed. I had to grind a little bit out of my wood. Also my bed floor is raised an inch and a half. if there is someone standing in the bed when lowered it just barley lifts the floor. Something I was thinking about doing is getting a rear cover and use it for the extra space. Something like a S10 rear.
Old 06-30-2009, 09:49 PM   #4
daverod
SSN 706
daverod's Avatar
Sweet I'm just posting so I'll be able to find it again. I'm just getting ready to mess with mine.
daverod is offline   Reply With Quote
Old 06-30-2009, 10:08 PM   #5
daverod
SSN 706
daverod's Avatar
I thought I got it. Now I'm confussed again. How does a watts link work? Anyone, anyone, You said It only move 1/4" thought the whole range of motion. What motion? The axle in relation to what? I'm lost Please someone beat this into my head. I want to know. Never mind I learned somthing new today.
Old 06-30-2009, 10:19 PM   #6
daverod
SSN 706
daverod's Avatar
If you did'nt have a watts link and were just using a pan bar how much would it move your axle over? What would it hit?
Old 06-30-2009, 10:21 PM   #7
onebad65c10
Gm for life.
I think it was over 2 inches. My tire would hit my stock rear wheel well.
Phil
CHEVY ONLY Baltimore, MD
65 Short wide: 383 stroker 5 spd
Toys:
D/D: 2017 Silverado LTZ2 crewcab
1969 Pontiac GTO Yes it is a real goat waiting its turn to be the car it was.
http://www.facebook.com/home.php#/pr...59&ref=profile
Old 06-30-2009, 10:24 PM   #8
daverod
SSN 706
daverod's Avatar
Well, I guess I better start looking for a watts link. Thanks
Old 06-30-2009, 10:26 PM   #9
onebad65c10
Gm for life.
Here you go.
http://www.kplinks.com/product.php?p...5&cat=5&page=1
Phil
Toys:
Old 06-30-2009, 10:28 PM   #10
daverod
SSN 706
daverod's Avatar
And another side job. I'm getting it.
Old 06-30-2009, 10:32 PM   #11
onebad65c10
Gm for life.
know that feeling. I bought mine with my tax money. Money well spent.
Phil
Toys:
Old 06-30-2009, 11:32 PM   #12
hotrodhomi
hotrodhomi's Avatar
I have the same one on my 2wd blazer.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 12-24-2009, 10:59 AM   #13
blue64
blue64's Avatar
speedway has one for 69.99 not exactly the same but should work. its a universal so it will need modification to the rods.
blue64 is offline   Reply With Quote
Old 12-24-2009, 11:18 AM   #14
SCOTI
SCOTI's Avatar
No disrespect intended, but 2" of side shift seems excessive even for an OE Panhard set-up within 'normal' limits of suspension travel (Bag @ ride height vs. fully compressed/extended). A better comparison would be the Watt's vs. a long/full chassis width Panhard bar.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-24-2009, 11:45 AM   #15
62gmc910
62gmc910's Avatar
YEP the grumpy old chassis builder would have to agree
When is some body (capt'n) gonna fab up a jacobs ladder???
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 12-24-2009, 11:51 AM   #16
CSoliz
Torn between 66 and 78
CSoliz's Avatar
Jacobs ladder? What would that look like?
CSoliz is offline   Reply With Quote
Old 12-24-2009, 12:12 PM   #17
62gmc910
62gmc910's Avatar
Old 12-24-2009, 01:25 PM   #18
SCOTI
SCOTI's Avatar
I've heard references of the Jacobs ladder but have never seen one installed in a vehicle. Any pics post installation?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-24-2009, 01:47 PM   #19
62gmc910
62gmc910's Avatar
The only thing I have is in old chassis books
Both of these installs have too steep of angles
Old 12-24-2009, 07:32 PM   #20
low79fx
Do you have any problems with this wheels in the back as far as rubbing on the quarter panels.I'm going to run a set on some BFG 255/60-15.Was just wondering.
low79fx is offline   Reply With Quote
Old 02-03-2010, 07:26 PM   #21
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
hey one bad any rattling going on with the watts link?? I know from the past that heim joint tend to get noisey......my old duece was terible till I change to rubber ends....
and what happens to the lip around the stock cover??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 02-04-2010, 09:14 AM   #22
lakeroadster
I would agree with Hottrucks as far as using steel rod ends in a street application. I have them on my Model A triangulated 4 bar set-up. MIne don't rattle but they do transmit a lot of noise through the bars and up into the frame. Urethane or rubber works better in a street application.
Educate me on this: For a street driven truck what is the advantage of the watts link over the standard panhard bar? I know the watts link keeps the rear end "perfectly" centered but is that really needed for a street driven truck? Wouldn't an adjustable panhard bar be "good enough".
Thanks,
lakeroadster is offline   Reply With Quote
Old 02-04-2010, 09:20 AM   #23
Hottrucks
Hottrucks's Avatar
Lake my consern is the wheels rubbing the fender somewhere either inside or out not only that but with air your never in the same place twice so a watts will keep it centered all the time...if it was static then a P bar is great.....If I don't do a watts I'm going to move the Pbar to the back of the trailing arm..the longer the less side travel
Old 02-04-2010, 03:06 PM   #24
lakeroadster
Hottrucks.. I may see the wisdom of the watts link myself here when I get my bomber on the highway this spring.
The rear tires on my truck are 33x12.5x15 and they are so close to the inner fender lip that I plan to cut the lip in half and then weld in some solid round bar to gain some additional space. This should provide for a solid smooth surface if I do have any rubbing when pulling into uneven driveways or other steep approach angled attack areas.
I like the look of almost no fender hanging out past the tire but it does come with it's "opportunities".
I have a static drop and a stock panhard bar. We'll see how things pan out once all the pieces finally come together.
Old 02-04-2010, 06:32 PM   #25
Hottrucks
Hottrucks's Avatar
Lake theres a post about rolling your fenders a bit ..I don't know where but I may have to do it myself I had my stock rallies cut and added 4" to the back space but with the 30X18.5x15 tire I think it will be close so I may have to roll the fender lip a bit.....
