06-21-2009, 06:44 PM | #1 |
plug gap.. hei dist.
what do i gap the plugs to im swapping to hei from points..
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
06-21-2009, 06:47 PM | #2 |
Moderator
Re: plug gap.. hei dist.
0.030 is what I use on my HEI.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-21-2009, 06:56 PM | #3 |
leddzepp,really? My books show .35 for points and generally .45 for HEI.
I converted to HEI (skip white-ebay) and left them at .35for 12,000 miles then 2 weeks ago decided to try .45. MORE POWER. Maybe 5% more. But I notice that mileage went down a tad. Try .45 on yours and let us know the diff. WLH
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
06-21-2009, 06:59 PM | #4 |
My Carbon Footprint
.35 if for points type dist. You want .45 and even more if you are running an MSD or some other control box. Check the manufacturer's recommendation but .45 on a HEI with no box
06-21-2009, 07:07 PM | #5 |
im getting ready to run accell
06-21-2009, 07:13 PM | #6 |
Moderator
Guess I am wrong. My truck runs great though.
06-21-2009, 07:23 PM | #7 |
Try it leddzepp,you're gunna like it!
06-21-2009, 07:43 PM | #8 |
My Carbon Footprint
With the "seat of your pants" dyno, the average motor will not feel much diff from .35 to .50 but you will get better burn at the correct gap.
06-21-2009, 08:43 PM | #9 |
Gone to greener pastures
What engine?
When GM started using HEI's back about '75, plugs were gapped at .060". In '77 they changed the gap to .045", except for the 250 c.i., I-6. The plugs for the 250, were gapped at .035". The 350's equipped with R44TX plugs had the gap set at .060". My service manual stops at '77 (I save everything!), so I don't know what other changes they may have made after that. So, I'd say that .045" would pretty much get you in the ballpark.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
06-21-2009, 08:44 PM | #10 |
20' Daredevil (Ret)
This is what I have always heard, and always done.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
06-21-2009, 08:49 PM | #11 |
Hollister Road Co.
I have mine at .050 with the Skip White HEI setup and R44ts
06-21-2009, 09:17 PM | #12 |
Restoration Virgin!
good stuff here....
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
06-21-2009, 09:56 PM | #13 |
My Carbon Footprint
Typically...the hotter the ignition, the wider the gap you can run. That's why the MSD's can run into the 60's but cylinder compression ratios come into play. This is why you need to stick to the manufacturer's recommendation for gap. If you got a used one from a friend, set it at .45 and go!
06-22-2009, 12:22 AM | #14 | ||
WLH wrote;
I'm telling you I gained maybe 10 HP which I definately felt "seat of pants" (which I don't consider any more sensitive than the next guys).
06-22-2009, 12:27 AM | #15 |
its the original 402 that came with the truck (1972) but its been rebuilt in 2004
06-22-2009, 12:37 AM | #16 |
the gap stayed the same till 87 and only the EFI engines had a different gap, the carbed HEIs after 76 stayed at .045
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project Last edited by Camper Power; 06-22-2009 at 12:38 AM. |
06-22-2009, 12:49 AM | #17 |
My Carbon Footprint
ah.....you are also asking the BBC PS questions huh?
06-22-2009, 12:50 AM | #18 |
BBC is still at .045 from what my book is telling
eh 1970 Chevy C20 daily driver 1975 GMC Jimmy 4x4 project 1966 GMC C10 Dad's project |
06-24-2009, 07:34 AM | #19 |
OurLadyofBlessedAccelerat ion
currently running 35 on HEI, going to regap to 45 today. great thread! thanks.
_______________________________________________ 1968 Chevy C-20 w/ 396 1997 HD Sportster 1200 street tracker 1994 Chevy 1500 Silverado |
06-24-2009, 08:07 AM | #20 |
Car Knocker
The book that I got from Jacobs Electronics stated that the optimum gap would be .10. Hard to believe. Tried it anyways. Truck ran great. Only problem was that after about 6 to 9 months the struck would not start. Seems like the plugs would burn up. Never at home either. So I would have to change plugs and it would start right up. Went back to .075 on the gap and have never had a problem since.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit. |
