Old 06-21-2009, 01:46 PM   #26
Naterman35
Re: bagging questions.
Ok another question. How to "paddle valves work"?
Heres a picture http://www.ecrater.com/product.php?pid=4290489
Naterman35 is offline   Reply With Quote
Old 06-21-2009, 02:01 PM   #27
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
1/4" lines forget it ...........it would take an hour to fill the bags
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-21-2009, 02:12 PM   #28
Naterman35
id still like to know how they work. i don't understand them.
Im using 1/2".
Im not going to do the whole thing in copper anymore. Im going to go D.O.T air line all the way till the cab. Then the visible part will all be copper or brass or somethi8ng similar.
Old 06-21-2009, 02:20 PM   #29
SCOTI
SCOTI's Avatar
Please..... 1/4" line will fill bags from deflated to ride height in under 2mins w/a small compressor. They may not be the 'trick' thing, but they will get the job done for those that aren't interested in playing around & just drive low all the time.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-21-2009, 04:58 PM   #30
Inverter
Inverter's Avatar
Never heard of such a thing. Looks like the manual switch opens a path from"tank to bag"when pushed in one direction and opens an air escape path"from bag" when push in another direction. Escaping air would come right out of the valve into your cab? Maybe theres a provision for routing the escaping air outdoors ?? Just guessing.
Imo,3/8 line is the seet spot.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 06-21-2009, 05:49 PM   #31
XXL
Seņor Member
XXL's Avatar
Exaggeration is fine, but your post just reads simply as bad information. Let's try to keep the bad information off the board. It confuses lots of people, who often parrot said bad information elsewhere, thus making things even worse for the community at large. This is why we need duct tape and plastic to save us from chemical weapons attacks and why people at my office were wearing surgical masks during the H1N1 "scare."
And that 2 minutes is likely with ONLY a compressor (no tank). With 6 gallons of stored air, lift time on my truck is about 20 seconds. More than reasonable for anyone who's just trying to change the ride height.
XXL is offline   Reply With Quote
Old 06-22-2009, 12:14 PM   #32
6772owner
Gearhead
6772owner's Avatar
Ok not to hi-jack here, but if you were use the Manual Paddle Valves wouldnt you need to get 4 of them to keep the air bags independent? If you only use two then the air would transfer between the bags, correct? At $80 for 4 of them and all the lines into/out of the cab is that really a deal? Just trying to get the info on this subject, seems very plausible for me.
2002 Saturn SL2, My D/D
2019 Ford Fusion SE, Ecoboost - Wife's D/D
1993 Camaro Z28, A4, CAI, Cat-Back Exhaust
Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD!
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644
6772owner is offline   Reply With Quote
Old 06-22-2009, 12:25 PM   #33
Naterman35
My understanding of them is yes if you only had two for all four corners then it will be a very rough sloppy ride and you'll be all over the place.
Plus with thoose the air is being dumped right into the cab... My understanding of them at least that's what i assume.
Old 06-22-2009, 12:30 PM   #34
6772owner
Gearhead
6772owner's Avatar
Ok cool, I found a pic of the back of them and it did look like it just has a hole between the 1/4" barbs to dump the air. I assume you could put another barb fitting in this hole and vent the air outside the cab if you got ambitious. Thanks for the info, maybe still a consideration....
Old 06-22-2009, 12:31 PM   #35
SCOTI
SCOTI's Avatar
Price a 4-way solenoid pack & 2x pnuematic paddle controls/gauges aren't bad. It depends mostly on whose set-up you go with (pre-fab solenoid set-ups or piece it together solenoids).
The big thing is the minimal electronic issues when using paddles. There are more/larger airlines that have to be plumbed into the cab, but it's not a big deal when using 1/4" line. If using 1/2" line, I would go electronic & use solenoids. You can plumb a 'dump' line so the dumped air is outside of the cab.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-22-2009, 12:36 PM   #36
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
I have the paddle switches on my 85. I have two 3 gallon tanks and two Viair 380 compressors. It will lift the rear from layed out to locked up in about 5 seconds. The front is not done yet so that may take a bit longer being that it is a lot heavier.
AVS_JASON is offline   Reply With Quote
Old 06-22-2009, 12:42 PM   #37
6772owner
Gearhead
6772owner's Avatar
Ok thanks for the info guys, I understand that the solenoids are about $300 for an 8 pack, I was just concerned with creating more places to leak and it being inside the dash LOL Im not that concerned with it dumping the air in the cab, I have the bags simply for the ride and ability to alter ride height with changing weight etc. AVS JASON do you have any pics of your set up? I would be interested in seeing them if you do. Thanks again to all!
Old 06-22-2009, 12:42 PM   #38
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
to advertise you need to be a paid vendor
Old 06-22-2009, 12:48 PM   #39
6772owner
Gearhead
6772owner's Avatar
Thats an awesome set-up buddy, is that a manufactured panel or custom made? Thanks for the pics
Old 06-22-2009, 01:05 PM   #40
6772owner
Gearhead
6772owner's Avatar
Ok cool, I will check it out. Thanks Again, Clay
Old 06-22-2009, 01:21 PM   #41
SCOTI
SCOTI's Avatar
What size lines?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-22-2009, 01:43 PM   #42
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
What size lines?
All 1/4" right now...
But I'm thinking of going with 1/2" from the tanks to the switches and then 1/4" the rest of it. Probably not though, since the 1/4" is already ran, LOL...
Old 06-22-2009, 01:50 PM   #43
6772owner
Gearhead
6772owner's Avatar
Do you think it would be best to run a 1/2" line into the dash and then split it to the (4) 1/4" supplies to the switches? I was thinking I could use bulkhead fittings at the firewall and then only have the (1) 1/2" and (4) 1/4" lines to deal with, any thoughts on this??
Old 06-22-2009, 03:03 PM   #44
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
My bad.... The guy asked to see my set up and I posted a pic of it.
Old 06-24-2009, 10:57 AM   #45
Naterman35
Tank came in today and the bags are supposed to be here later today or tomorrow.
Then need to just get all the fittings and line this weekend.
Old 06-24-2009, 04:47 PM   #46
MTCHEVY
MTCHEVY's Avatar
AVS Jason - Can I get a pic of you paddle switch setup....I sent you a personal e-mail
-M.J.
1968 Stepside
MTCHEVY is offline   Reply With Quote
Old 06-25-2009, 09:34 AM   #47
au03z71
au03z71's Avatar
1/4" lines work great IMO. They give you finer, slower control and won't give you whiplash when you air up your bags (although I know some people like that).
au03z71 is offline   Reply With Quote
Old 06-26-2009, 01:09 AM   #48
rckclmbr99
rckclmbr99's Avatar
one of my buddies had 1/4 lines and paddle valves from way back and he ran it for a few years and didnt really have many problems. it is slow but it gets the job done. just dont expect to be able to hit any mad switches haha
18 and workin' on the first build ('69 C10)
2002 Chevy Silverado REG cab, Short bed, 5.3 V8: Murdered.
Club: B-Low Average keepin' it real and low
rckclmbr99 is offline   Reply With Quote
Old 06-26-2009, 11:26 AM   #49
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
"Hitting switches" is overrated anyways. LOL....
I would rather pull up to the stop light and be rolling lower then the other guy. Not jumping around, trying to have a dance off. That's just my opinion though...
Old 06-26-2009, 04:22 PM   #50
rckclmbr99
rckclmbr99's Avatar
ya i hear ya. it is fun to hit switches at people walkin down the side of the road though b/c its kinda loud so they piss their pants then the think your truck broke haha
