Old 06-22-2009, 09:53 PM   #1
brawley
Easy Does It
brawley's Avatar
odd patch panels ??
Does anybody know of a source for filler patch panels for openings like the bed stake pockets, gas cap, park light fillers, ect... thanks.
brawley is offline   Reply With Quote
Old 06-22-2009, 10:20 PM   #2
70 Suburban
Rods
Re: odd patch panels ??
ebay ......
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 06-22-2009, 10:58 PM   #3
LILRED66
LILRED66's Avatar
Actual patch panels for shaving the areas you are looking to smooth are not available in the aftermarket, however, you can purchase light gauge sheet metal from your local home center and cut the pieces you need from cardboard patterns. This is an economical way to do what you want to do and you can chose the thickness of the material you want to use, instead of working with the very light gauge material the imported patch panels are made from. Good luck with your project and keep us posted with what you end up doing.
LILRED66 is offline   Reply With Quote
Old 10-11-2009, 10:04 PM   #4
brawley
Easy Does It
brawley's Avatar
I found some gas cap,and stake pocket filler panels on ebay for 67-72 trucks , but im not sure if they will work on 60-66,also mar-k has some stake pocket caps that push in.
Old 10-12-2009, 12:46 AM   #5
Captainfab
60-66 Nut
I would suggest what Tony did. Just get some 18ga cold rolled sheet and cut them out yourself.
