Old 03-28-2003, 04:45 PM   #1
jolt
94 K1500 ExtCab wearing pitarm
Hi, I'm new here.
I have a 94 Silverado K1500 Stock Suspension 3" Body Lift 33x12.50 tires.
About every 6 months it wears out the pitman arm and I get that horrible wobbling at about 40 mph.
I've heard that this is common for stock vehicles with oversized tires and that there are some modifications that can be done to prevent this, however I can't seem to find any information on this. Is anyone familar with the problem I'm describing and maybe know what I can do about it?
Thanks for any advice or suggestions.
JO
I've never failed. I've just found thousands of ways that don't work.
jolt is offline   Reply With Quote
Old 03-30-2003, 04:23 PM   #2
sakohntr
sakohntr's Avatar
arms
This is common. The idler arm usually goes first. They make a light duty and a heavy duty version. Get the heavy duty one. Also, when it does start to have wear in it, unbolt it and then rotate the arm 180 degrees and bolt it back up. This way it will wear on the opposite side. It will buy you some more time before replacing.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
