06-23-2009, 12:52 AM | #1401 |
Re: My 1965 build thread
Hey Alan I took your advice and made sure the lift has a stop on it. It got up pretty high and no wobble. By the way your truck looks great!
06-23-2009, 10:31 AM | #1402 |
Daring to be Different
Looks like you decided to use it at work.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
06-23-2009, 11:17 AM | #1403 |
Rods
Im useing the stock v8 mounts from my 283. I dont have to dimble the header on the drivers side but it has about .010 clearance on the perch. But my truck is a stanadard and all the linkage clears. They are not pretty but ill get some pics for you tonight when i get home. Btw congrats on your money making lift
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
06-23-2009, 09:50 PM | #1404 | |||
1 thing at a time is progress.
It finally went to paint today. That job kicked my butt. Quote:
Yeah for now. finally got a car on it today. I had to go yesterday and get a fitting for the pump for the hose to hook up. Evidently there might be a restrictor that goes in the line cause the car comes down too fast. Even if your careful with the lever. I'm waiting on the manual to get here so I can see the IPB. Quote:
Sdailey ordered some parts from Jegs and I jumped in on the order and got some fittings and hose for the power steering. I'll get some pics soon. Going to bed early tonight and rest.
Alan
Philippians 2:14-16 |
06-24-2009, 12:48 AM | #1405 |
Member of the longbed union.
your going to bed at 8:50 you panzy. haha, keep up the good work Alan ZZZZZZZZZZZZZZZZZZZZZZZZZZZ
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
06-25-2009, 12:12 AM | #1406 | |
Here's a couple shots of the fittings for the power steering. Does anyone know if there is an adapter that can be brazed onto the return line at the pump for a -6 fitting?
Alan
06-25-2009, 12:57 AM | #1407 |
60-66 Nut
I don't know if there is a special fitting or not, but you could probably do it with the right size NPT to -6 steel fitting.....one that will fit over the return tube.
06-25-2009, 08:56 AM | #1408 | ||
I'm just glad to be here!
They make a fitting that is a compression nut/ferrel on one end and the other end is a -6 JIC steel fitting. I know that Parker fittings for hydraulics should have one. Does the return line on the pump have a bead near the end of the tube? If it does, it will need to be cut off and the compression fitting would need a straight section of tube long enought for the ferrel and nut to seat correctly. Here is the link to the fitting: http://www.parker.com/portal/site/PA...20STEEL&Wtky=# Part number 6 XHBU-S is for 3/8" tube to -6 straight fittings, they should also be available in 90 and 45 degree fittings. Hope this helps. Here are the local distributors to your area (within 60 miles):http://www.parker.com/portal/site/PA...odifier=&Wtky= You have to put in your zip code...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square Last edited by aggie91; 06-25-2009 at 08:57 AM. Reason: link needs zip code... |
06-25-2009, 10:01 AM | #1409 |
283 Drama Queen
Glad to see you're back at it, Alan.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
06-25-2009, 10:34 AM | #1410 |
The Few, The Proud
Alan we deal directly with Parker and their fittings here at work. Let me know if you need something.
Shannon |
06-25-2009, 11:26 AM | #1411 | |
Sunburst C10!!!
why dont you just run hoses
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 06-25-2009 at 11:27 AM. |
06-25-2009, 11:59 AM | #1412 |
yeah it would have, I didn't take in the time change. But glad to see your back at it Alan.I think we were all sad that not much got posted yesterday, I know i look forward to it. I know it makes me feel better to see progress on everyones truck when i'm having a hard time on my back half!
06-25-2009, 01:33 PM | #1413 |
Sunburst C10!!!
hey alan what motor mounts are those
Gage 1967 C10 Shortbed Stepside |
06-25-2009, 01:45 PM | #1414 |
Rods
YOU KNOW ALAN I WAS THINKING. ARE YOUR PARCHES DIFFERENT OF IS IS JUST THE MOUNTS. ALSO i DONT THINK IT WOULD BE A PROBLEM TO RAISE THE ENGINE UP. INFACT THATS WHAT I WANT TO DO WITH THESE HEADERS FOR GROUND CLEARANCE.
06-25-2009, 02:01 PM | #1415 |
^ makes me laugh every time
CHEVY ONLY |
06-25-2009, 02:27 PM | #1416 |
Rods
lol sorry cant help it....Life in shop managment is tuff some times.
06-25-2009, 02:30 PM | #1417 |
CHEVY ONLY |
06-25-2009, 08:48 PM | #1418 | ||||
Thanks Mac. I thought i was better, I guess it's just a summer time cold. You scared me with that pic of a guy riding a fish with a G string in your thread. I'm running steel braided nylon hoses. Quote:
I orderd them for a 69 camaro. Quote:
Habits are hard to break.
Alan
06-25-2009, 08:52 PM | #1419 | |
Sunburst C10!!!
thanks for the info
06-26-2009, 11:51 PM | #1420 | |
I thought OK, I get to do something to my truck. I had a couple little things to do thinking it would be easy..........think again. I thought about putting the fitting on first and said nah, lets put the door handles in since I got my lock cylinder yesterday from Tim Christian. It's just a simple lock cylinder why can't I get it too work. Here is a pic If I remember right you have to put key in and push and turn to lock it, right? The first washer that I put on with the slot in the middle will not allow it to turn. It's got some dimples (keyways) stamped in it that is preventing it to turn. Lock cyl turns fine with it removed. Here is a pic of the washer installed. I'm thinking of just filing the edge keyway down so it will turn. Here are the next pieces I installed then that is followed up with a snap ring. Complete. I did assyemble it right, right? I didn't have a pic to assy it by. It just looks like this is the way it goes. Since I was having trouble with that I figured I could get the passenger side handle in. Wrong. of all things that I thought of test fitting, I didn't think of the handles. Now I have some grinding to do. So these little task turned in to a PITA. It's just part of it, gotta keep moving.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 06-16-2011 at 11:12 PM. |
06-27-2009, 12:01 AM | #1421 |
wow man that sucks....I will pull out our original driver's door handle tomorrow and take a look, if no one has solved the mystery by then.....
CHEVY ONLY |
06-27-2009, 12:35 AM | #1422 |
Alan, Don't grind yet. I did my door handles as well about a year ago and faced the same thing. I took them to my local locksmith to get them matched to my ignition/glove box, only charged me $20. I am trying to remember what I did, I am trying to remember.......argggggg
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it |
06-27-2009, 12:38 AM | #1423 |
Btw you dont have to push in to lock it. Just turn to lock it and then you can't push it in any longer.
06-27-2009, 01:01 AM | #1424 |
I cant remember, I cant remember...sorry Alan. I do know that you can assemble and test it without putting it in the door, it should lock and not allow you to push the button. Hope any of this helps :P
06-27-2009, 10:12 AM | #1425 |
chevy only
ALAN I HAVE BEEN BUSY AND NOT MUCH TIME TO WORK ON MY STUFF LATELY BUT I ALWAYS CHECK YOUR PROGRESS ,SUCH NICE WORK GREAT JOB AL
CHEVY ONLY... Nothin Else ! |
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
