Radiator Hose Selection
hey guys, im wondering if anybody can give me a specific part # for the radiator hoses that i would need.
i have a 66 chevy c-10 that i just put a 350 in and am hoping to fire it up within a day or so. ![]() |
![]() Join Date: Sep 2006
Re: Radiator Hose Selection
Are you using a stock radiator? If so you can just use the stock lower for the 283 or 327 for 66. As for the upper. I believe I used one for a mid 70's truck. I think I even trimmed it a bit but it works.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
i forgot to mention that i am using the factory radiator for now. hopefully upgrading when my money tree blooms again.
#4 | |
are you running a stock radiator too? does it cool the engine ok? im a little skeptical about how its going to work. Last edited by Green66Shortbed; 06-24-2009 at 10:36 AM. |
I have not driven the truck for a few years now. I changed to a BBC and an aluminum radiator. It should cool just fine. I never got my temp gauge dialed in right but it seemed to be fine. I also used an electric fan which wasn't so great. Had a terrible sensor for turning it on and off. You should have a problem as long as the radiator is free and clear. I did have a new one.
Resistance is Futile
My friend does a bunch of custom installs and upgrades. He bends a wire in the rough shape that is needed for the hose and takes it to the parts store. They let him look at the hoses and find one that is close to the shape he bent. Just a suggestion.....something to try.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#7 | |
P.S.- i was excited to see that protrash64 had commented in my thread. ![]() |
60-66 Nut
If you're using the original style thermostat housing as Chevy Fleetside is then you can use Car Quest #20607 for the upper hose. If you're using the newer angled thermostat housing try one for a '69-'72 truck. One for a '68 Camaro will work too.....might have to trim it some.
