Old 06-25-2009, 01:34 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
Hydro-boost brakes...Good?
I found a Hydro-Boost brake Booster with power steering pump that a neighbor is willing to sell for $50. He said it fits older GM trucks; it came out of 79 1 ton 4x4 Chevy. I have power brakes already but he said this set up is better than power brakes. Is anyone running this set up? Would it be a good deal? How does it compare to power brakes? How much do you guys think something like this is worth? Any advice or opinions would be appreciated. I will attach a pic.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 06-25-2009, 01:47 PM   #2
grancuda
grancuda's Avatar
Re: Hydro-boost brakes...Good?
I don't care for the set-up just due to the extra parts required over vacuum assisted brakes. I had them on a '87 Grand National.
grancuda is offline   Reply With Quote
Old 06-25-2009, 01:48 PM   #3
69sixpackbee
Theyr'e great as long as you don't spin the P/S belt just prior to a panic stop!
Ask me how I know
69sixpackbee is offline   Reply With Quote
Old 06-25-2009, 02:00 PM   #4
69halfton
69halfton's Avatar
i'd have to agree with 69 1/2 six pack, i would think that vacuum would be a more reliable system... just because of its simplicity. but I've never owned a hydroboost system.
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 06-25-2009, 02:48 PM   #5
turp mcspray
turp mcspray's Avatar
If you have 40inch tires on a 4x4 it is the way to go. If it's a smalled tired truck ur a 2wd probably overkill. On my blazer with 36" swampers It would lock up all 4 tires on the street with the stock power disc setup.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 06-26-2009, 10:27 AM   #6
lts70
1970 Daily Driver
lts70's Avatar
Sounds like I will pass on this one then. My truck is a lowered 1970 SWB.
Old 06-26-2009, 01:21 PM   #7
ERASER5
ERASER5's Avatar
I would buy it. The hydro has a lot more braking force than the vacuum booster provides. Also, if you have a lumpy, low vacuum cam, the hydro is the answer. For $50? It would be in my garage pronto!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-26-2009, 02:12 PM   #8
fastom
That's right, it's Copper!!
fastom's Avatar
Love my setup. Disk brakes all around with hydroboost, works better than my 2005 truck. I would never say it's "Overkill", it just work great!!
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Gen-II Compact Vintage Air System
PPG paint, Mandarin Copper and Vanilla Shake.
http://www.hubgarage.com/mygarage/fastom
Stupid should hurt and eventually become fatal!
fastom is offline   Reply With Quote
Old 06-26-2009, 02:14 PM   #9
Aunt-Jemima
I've never drove an old truck with it but the vaccum is just so simple
1969 c20 350/th350(shift kit) A/C cab custom headers and exhaust
1972 c10 307/th350 (wrecked) possibly selling
Aunt-Jemima is offline   Reply With Quote
Old 06-26-2009, 02:23 PM   #10
jaros44sr
jaros44sr's Avatar
Looks like I will be searching the junkyards for a '79 1 ton 4x4
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-27-2009, 05:21 PM   #11
c-10ss
i just finished intalling my set up using a astro van unit , all i have to say is wow . Made such a huge difference in braking
c-10ss is offline   Reply With Quote
Old 06-27-2009, 06:09 PM   #12
Beefcake
sounds like a must for tow rigs!
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 06-27-2009, 08:57 PM   #13
turp mcspray
If searching salvage yards, it came on 1 tons and diesels,just to name a couple. Should be real easy to find.
Turp Mcspray
Old 06-27-2009, 09:24 PM   #14
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
I would use it in a heartbeat.....
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 06-27-2009, 11:04 PM   #15
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Hydroboost brakes are great. The stopping power is awesome. Especially with four wheel discs. For $50, you cant go wrong. It also clears up room between the booster area and valve covers, especially with a big block.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 10-07-2013, 05:25 PM   #16
Bczik84
So did we decide if there were for better or worst I have them on my 77 c30 camper special with a cummins nv4500 swap doing a frame off so its its not gonna work that hard anymore but I want reliability and good
Bczik84 is offline   Reply With Quote
Old 10-07-2013, 06:12 PM   #17
duallyjams
duallyjams's Avatar
I'll send you the money and you can buy it for me.Hydroboost pedal have a better feel then vacuum.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 10-07-2013, 06:15 PM   #18
DWilbur
A friend of mine has them on an 1987 Chevy 1 ton they work great Especially with larger tires. If you loose the pump or kill the engine you have 1 chance to stop hold your foot on the brake pedal and keep pushing until you come to a complete stop.
DWilbur is offline   Reply With Quote
Old 10-07-2013, 08:31 PM   #19
WIDESIDE72
WIDESIDE72's Avatar
I have had several trucks with hydro boost (80 gmc 1 ton gas, 82 suburban 1/2 ton diesel 88 1 ton gas, 93 3/4 ton 4x4,01 and 02 2500hd diesel) and they stopped great. They were offered on heavier gvw trucks due to their increased assist and diesels since they have low vacuum. I only had trouble with one leaking. I am not sure i would go to the teouble of installing one one a light duty 1/2 ton unless their were vacuum or clearance issues, but as stated above, for $50 i would snag it!
WIDESIDE72 is offline   Reply With Quote
Old 10-07-2013, 08:32 PM   #20
WIDESIDE72
WIDESIDE72's Avatar
With vacuum brakes you only get one shot to stop with assist if the engine dies as well. No running engine means no vacuum.
Old 10-07-2013, 08:37 PM   #21
ls1nova71
ls1nova71's Avatar
Personally, I don't see how it's possible to "overkill" a system as important as brakes.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 10-07-2013, 08:40 PM   #22
71swb4x4
71swb4x4's Avatar
This thread is over 4 years old.
I have hydroboost and like them, but that's on a one ton. I don't think they would be great on a half ton, when I slam on the brakes it puts me into the steering wheel in a hurry. On a lighter truck I would be afraid that you would lock up the wheels way to easily.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 10-07-2013, 10:52 PM   #23
909
If the engine died wouldn't the hydroboost system quit working aswell?
909 is offline   Reply With Quote
Old 10-08-2013, 01:59 AM   #24
WIDESIDE72
WIDESIDE72's Avatar
I meant to quote the post above where they mentioned that hydroboost only worked if the engine was running.
My point was that this is a non issue. Neither sysem works but once if the engine dies.
Old 10-08-2013, 09:12 AM   #25
duallyjams
duallyjams's Avatar
Astro vans came with hydroboost brakes.
James
IG duallyjams
