Old 06-26-2009, 04:46 PM   #51
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Re: bagging questions.
HAHA... You could just mount a dump valve from your tank pointing out towards the front. Or even better, just get a set of train horns.
AVS_JASON is offline   Reply With Quote
Old 06-29-2009, 07:46 PM   #52
Naterman35
lol i vote train horns....
Well i bought my ball valves and all my fittings. Im outa school for a week though and cant put them in my truck
Naterman35 is offline   Reply With Quote
Old 06-29-2009, 08:32 PM   #53
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
get everything mounted up then you can just put the bags in...the part that take the longest is getting all the air lines in and mounting them tight the bags will take no time at all
Hottrucks is offline   Reply With Quote
Old 06-29-2009, 08:33 PM   #54
Hottrucks
Hottrucks's Avatar
and take some pics!!!!!!!!
Old 06-29-2009, 10:24 PM   #55
Naterman35
Grr. I cant seem to find my SD card reader or id have quite a bit...
All i have a picture of is my tank and my valves...
I dont have school and unfortunately my trucks locked inside the school. And mounting the bags... easy...PFFT. Ever tried drilling through a frame rail...Far from easy. I went and bought some new bits because the old ones were just plan crap.
Old 06-30-2009, 11:53 AM   #56
joe231
joe231's Avatar
you just need the "right" bits....I have these, they aren't very expensive and they cut like butter, even through stainless steel.
http://www.homedepot.com/webapp/wcs/...ctId=100634630
under $20 at home depot, or for @$60 you can get a bigger set....
http://www.homedepot.com/webapp/wcs/...ctId=100618921
with the pilot point you don't need to drill pilot holes first.....I use these at work and haven't had a dull one yet, I mostly bend/break them before they get dull. I have drilled some heavy stuff with them.
It is the only bits I will buy....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 06-30-2009, 01:08 PM   #57
Naterman35
I bought some titanium tipped ones.
I asked the worker what bit they would recommend to drill through1/4inch plate steel... They said that... Ill find out next Monday if there right or not.
I also realized last night i only bought 3 valves... I thought i bought 4... but apparently not.. Looked at my receipt and says 3.
Next payday im buying the line as well as one more valve, and 3 more fittings.
Old 06-30-2009, 01:11 PM   #58
joe231
joe231's Avatar
be sure to drill a pilot hole first and take it fairly easy or you will smoke the bit.
if you get a chance try out the dewalt bits....
CHEVY ONLY
Old 06-30-2009, 01:24 PM   #59
Naterman35
Im planning to do the pilot whole ill probably try to use some cutting fluid to.. see how that treats me.
Old 06-30-2009, 04:30 PM   #60
Hottrucks
Hottrucks's Avatar
I hate to be an asshat and all but the best thing to use is a UNI BIT ( or step bit) up to 3/4" you'll need it for the air line fittngs now I'll tell you from personal experiance use a T on top of the rear bags one side goes to the air valves to fill it the other is for the dump....if your using electric valves.....or you can put your air guages lines there....keep in mind the closer to the bags the vavles are the less air it takes to air up!!!! if you don't go with the T's plan on a 90* fitting at the top of each bag to get the air lines going in the right directions
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 06-30-2009, 05:06 PM   #61
joe231
joe231's Avatar
on the uni-bit, that is what I use when I need a hole bigger than 1/2"
They can be spendy, but they are worth it, nice clean holes too.
CHEVY ONLY
Old 06-30-2009, 07:53 PM   #62
Naterman35
Im only drilling 3/8's wholes tho...
Old 06-30-2009, 08:18 PM   #63
joe231
joe231's Avatar
what about holes for the air line?
CHEVY ONLY
Old 06-30-2009, 08:45 PM   #64
N2TRUX
Happy to be here
N2TRUX's Avatar
If you do buy a Uni-bit, make sure you get a quality one. There are cheap bits out there, and they suck.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-30-2009, 08:49 PM   #65
joe231
joe231's Avatar
expect to pay close to $30 for one.....
CHEVY ONLY
Old 06-30-2009, 09:40 PM   #66
protrash64
Resistance is Futile
protrash64's Avatar
Originally Posted by AVS_JASON View Post
I have the paddle switches on my 85. I have two 3 gallon tanks and two Viair 380 compressors. It will lift the rear from layed out to locked up in about 5 seconds. The front is not done yet so that may take a bit longer being that it is a lot heavier.
I used 1/2'' line with about 5' of run to the bag and it takes about .5 seconds...
Originally Posted by au03z71 View Post
1/4" lines work great IMO. They give you finer, slower control and won't give you whiplash when you air up your bags (although I know some people like that).
...I would use 3/8's as a happy medium doing it over. I got 1/2'' valves and just stuck 1/2'' line on them.....seemed consistent when I didnt know what was up.
"Hitting switches" is overrated anyways. LOL....
I would rather pull up to the stop light and be rolling lower then the other guy. Not jumping around, trying to have a dance off. That's just my opinion though...
NO KIDDING!!!!! See the first response above This is not an exaggeration at all!!!
Originally Posted by rckclmbr99 View Post
ya i hear ya. it is fun to hit switches at people walkin down the side of the road though b/c its kinda loud so they piss their pants then the think your truck broke haha
... ya no doubt!!!!!!!
Here is something else to keep in mind about air set-ups that I learned. I placed my valves all the way in the rear just behing the back bumper. 1/2'' with 1/2'' line. The front has approx 10' of line which eats quite a volume of air....this helps with the control. But, as stated above, the rear lines are only about 5' long to the rear bags. When I make an adjustment to the rear it hits so hard it will shake a person in the seat. I tap the switch as lightly as I can. If I dont, my 'burb looks like a sub doing an emergency dive!!!
Just thought I would share my experiences.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-01-2009, 08:11 PM   #67
Naterman35
Were the line will come out its right in the middle of that cross member. I plan to notch it or build a whole new cross member.
Old 07-02-2009, 05:46 AM   #68
Hottrucks
Hottrucks's Avatar
Ummm Like I said about 10 posts back plan on a 90* fitting and a short 2" entention....put your bag in loose put in the 90* then add the extention so your air line fitting will extend to the back or front of the memeber......that what I did and it worked like a charm
