Old 06-28-2009, 10:03 PM   #1
dave01
69 4x4
hi ihave a 69 4x4 with drums i bought axles from a 88 sub for the disc brakes will the hardware fit or should i try a axles swap? the mounting points measure out but i'm not sure can somebody help me?
thanks dave
dave01 is offline   Reply With Quote
Old 06-28-2009, 10:11 PM   #2
msgross
msgross's Avatar
Re: 69 4x4
welcome Dave.. i'm gonna move this to the 4x4 section...
If you look at my 68 K-10 build you will see that I stuck an 82 corp 10 bolt under my 68.. yes it bolts up but there are other changes that need made.
1. did your 69 have closed knuckles or open (does it look like a ball and socket joint where the wheel turns on the axle? You should be able to link your steering right up. If it's an open knuckle axle then you can also swap all the parts from the spindle and out so that you don't have to unbolt your axle.
2. More than likely your calipers will have metric banjo bolts, you will need new brake hoses unless you got those from the donor, expect to buy some adapters along the way..
3. Did you get a front sway bar from the donor? You can make a mount for it if so
4. Is it a 3" axle tube? If so then pull the top spring plates from the donor and get new u-bolts to fit. Your old axle was more than likely 2.75"
5. Are the gears the same? I hope so, if not keep searching for a matched set to go with your rear...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-28-2009, 10:22 PM   #3
dave01
Re: 69 4x4
hey thanks for the comment msgross it has open knuckle's and all i got was the axles from the sub and your right the 69 axles are a smaller diameter. i'm thinking swap the hardware and keep the 69 axles so all i need is the boost,master cycl, and portin valve
Old 06-28-2009, 10:31 PM   #4
msgross
msgross's Avatar
Re: 69 4x4
Best bet is to get a complete setup from one of our vendors. You will also need the brackets that go with the booster.
something like this should work, except that your from hard lines will more than likely need swapped too. We have board vendors that carry these parts too..
http://www.classicperform.com/Store/...ck/6772BBD.htm
The Garage:
Old 06-28-2009, 11:16 PM   #5
Captainfab
60-66 Nut
Re: 69 4x4
I can provide you with a booster mounting bracket if you are in need of one. There is a link in my sig.
