Old 06-29-2009, 03:42 PM   #1
ol'blu72
Pull oil pan engine installed??
Title says it all. Is it possible to pull the oil pan with the engine installed?
on a 72 blazer 350/th350 BTW incase your not checking the sig.
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
Old 06-29-2009, 03:55 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Pull oil pan engine installed??
Most of the time, it is MUCH more of a pain to try and do it in the truck. I've heard that if you just get the engine/trans to where you can hoist it up about 3" or so, it will make life a LOT easier.
My uncle just had to do this on his '67 F**D. Different animal, I realize, but his mechanic ended up all but pulling the motor to do it.
Good luck!
69GMCLonghorn is offline   Reply With Quote
Old 06-29-2009, 04:01 PM   #3
MonteSS454
MonteSS454's Avatar
Harmonic balancer at 6 o' clock and jack up under the tranny and bit and everything should clear to pull it out. Done it myself.
MonteSS454 is offline   Reply With Quote
Old 06-29-2009, 04:24 PM   #4
ol'blu72
I dont get it? balancer @ 6 o'clock? do i need to unbolt the motor mounts then jack up the engine?
Brad
Old 06-29-2009, 04:49 PM   #5
danw210
69 K20
I did mine by unbolting the motor mounts, removed the distributor, and used a hoist to pull the motor up. It worked very well. As far as turning the balancer I did not do that. I would imagine that it helps with the crank weights, probably moves them out of the way at 6 o'clock, just a guess on that one.
danw210 is offline   Reply With Quote
Old 06-29-2009, 05:41 PM   #6
neonlarry
neonlarry's Avatar
Thats correct with the balancer in that position you will get the most clearance of the counterweights.
And yes unbolt the motor mounts. I would have answered before but I'm not sure on 4X4 how much clearance you have to raise the 205 and or what the front member looks like with the solid axle. Hopefully some one with a 4by will chime in.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 06-29-2009, 06:00 PM   #7
ol'blu72
With the balancer position are we talking timing marks at 6 o'clock. Well i guess thats kinda a stupid question thats the only mark on the balancer right.
Brad
Old 06-29-2009, 06:42 PM   #8
danw210
69 K20
I did it on my 4x4.
Old 06-29-2009, 06:59 PM   #9
LONGHAIR
It's a lot easier on a 4x4.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-29-2009, 08:01 PM   #10
ol'blu72
Thanks for all the input guys I dont know what I would do without this site.
Brad
Old 06-30-2009, 06:54 AM   #11
gator2511
gator2511's Avatar
Angry Re: Pull oil pan engine installed??
On my 72K10 I had to remove the cross member and the motor mounts to get the pan out. Maybe if I had known about the balancer trick I could have saved myself some big trouble. I also did the usual stuff like remove the dizzy and jack up the front of the motor. Lots of work. Don't want to do it again.
gator2511 is offline   Reply With Quote
