06-29-2009, 08:45 PM | #1451 |
Sunburst C10!!!
Re: My 1965 build thread
exactly
Gage 1967 C10 Shortbed Stepside |
06-29-2009, 09:30 PM | #1452 | ||||||
1 thing at a time is progress.
The pic didn't show up on my end. Thanks Man!! Quote:
Me too!!
Alan
Philippians 2:14-16 |
06-29-2009, 09:40 PM | #1453 |
Daring to be Different
I thought you went into the shop to work. Do you have a computer in there too?
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
06-29-2009, 09:45 PM | #1454 |
We need to have them both ready by August..........Did I mention bonus
06-29-2009, 09:51 PM | #1455 | |
Hummm, If your weekly budget can handle it, it is possible. At least your could be done that fast.
Alan
06-29-2009, 10:15 PM | #1456 |
06-29-2009, 10:46 PM | #1457 |
One day...
06-29-2009, 10:56 PM | #1458 |
Ya'll ask for them now here they are.
Wrapped with tape a little tighter than last night and also used a zip tie to keep everything together. Use a little oil to assymble. One complete hose Went ahead and put one end on the return line. The one I did last night I used on the pressure side. I still need the 5/8" adapter for return port.
Alan
06-29-2009, 11:17 PM | #1459 |
SSN 706
Ah, ya that was good.
06-29-2009, 11:19 PM | #1460 |
Member of the longbed union.
looks good Alan, I'll have to keep that in mind when I hook mine up. But I'm running a m--t--g rack! I didn't want to spell a bad word!
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
06-30-2009, 10:23 AM | #1461 |
Try Duck Tap next time. I had the same problem. I tried masking tape, and electrical tape. The Duck Tape is stronger, and holds it together better. Any other ideas out there?
BTW looks good Allan.
06-30-2009, 10:46 AM | #1462 | |
Shloooooong bed member #2
We used duct tape also, but we also added 2 hose clamps and left a small gap between them and then used our cutting wheel. Another option is a cable cutter simular to the one below. But by the look of things you got it.. looking good
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
06-30-2009, 10:58 AM | #1463 |
Nice hoses Alan, awesome work!! would you be able to share the size and/or part numbers so we could make the same hoses? I have seen them in catalogs but I think they want upwards of $150.
How about using that aluminum tape that they use for a/c ducts? It's strong and also nice and stiff. Just a thought.
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it |
06-30-2009, 07:07 PM | #1464 | ||||
Alan
06-30-2009, 07:25 PM | #1465 |
Schlongbed MEMBER (heh)#15
Braided is the only way to go. Lookin awesome.
82 Chevy Blazer 4wd.RIP 1965 Chevy C10,350V8 Get it reliable,then puttin' it in the weeds.. "Old truck, all new headaches." |
06-30-2009, 10:06 PM | #1466 |
Alan,
What ever your doing.. keep it up...Everything is looking sharp..
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q Last edited by 4dranch; 06-30-2009 at 10:07 PM. |
07-01-2009, 11:55 PM | #1467 | |
Rebuilt a vent window tonight. Over all it is fairly easy. I had some issues of what goes on first. When I rebuild my other side I will get the order of the way it goes and post a thread on it. I took pics tonight, but I did things out of order so it would only confuse you and make life hard on those that follow what I did tonight. Here it is somewhat completed. The second pic shows where the vent window latch is supposed to be. I thought the pivot pin was available, but tonight I couldn't find anyone that sells a repair kit. I'll do some calling around. Also in the second pic I don't like the big gap between the inside part of the door and the vent window. Also I will have to drill some holes in the door where the bottom of the window track goes. I put the vent window in just to see what other issues I have. It will have to come back out in time. At least it's somewhat safe in the door.
Alan
07-02-2009, 12:24 AM | #1468 |
Wow is that a silver metallic flake that you are using on the upper portion of the cab? That looks really good with the orange. Have you posted a picture of the truck from a distance and I missed it
Would you recommend rebuilding the vent window or going with the delete kit and making it a single window? or is that really just a personal choice?
07-02-2009, 01:00 AM | #1469 |
I'm going to recomend that you go with a vent window rebuild. No one sells a single window for our trucks, because of the fact that it's not secure when the window isn't all the way up. Everyone that has had it done, had the glass cut and peiced a kit together! That's my understanding from autoloc. Truckin did a spread on it and also stated the same fact.
Looks good Alan cant wait for your window thread!
07-02-2009, 09:09 AM | #1470 |
Thanks ruffrida! Good enough to convince me
07-02-2009, 09:32 AM | #1471 | |
http://www.classictrucks.com/tech/04...ows/index.html |
07-02-2009, 12:39 PM | #1472 |
that link didn't work. I would love to have a one peice window kit. but have been told that it's not secure when the window isn't all the way up
07-02-2009, 01:20 PM | #1473 |
Sunburst C10!!!
i like the vent windows especially with no a/c
07-02-2009, 02:00 PM | #1474 | |
283 Drama Queen
Mac.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
07-02-2009, 02:36 PM | #1475 |
I'm going to go with a single window conversion myself. I'll be utilizing a power regulator of some sort scavenged from somethin or other...
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
