Old 06-30-2009, 08:54 PM   #1
redbaron69
redbaron69's Avatar
SPID question
need a little help here with the SPID on my 69, would have just posted a pic but my POS camera is being a PITA.
code reads 4b85ab body side moulding my truck has just the upper. is there a seperate code for lower moulding?
next one is 4534?? white/olive green cant make out last two here, does this mean the top of the cab was white,and no where else?
and 4612ba green vinyl trim, im guessing dark green interior
thanks guys when i bought the truck it has been repainted red every where even the bumpers! tryn to make some decisions on which way im going to restore this truck terry
69 short fleet 350/350 "under construction"
70 short step 307/3 speed
redbaron69 is offline   Reply With Quote
Old 06-30-2009, 09:30 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: SPID question
B85 is indeed upper body side moulding. fyi, BX2 code is for the wide lower moulding.
the upper cab was white seperated by a small stainless steel moulding at the rear of the cab. The remainder of the truck was more than likely olive green.
612 green vinyl is a standard green vinyl bench.
Olive green IS the sharpest color of these trucks....... but I am a bit biased!!!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 06-30-2009, 09:35 PM   #3
redbaron69
redbaron69's Avatar
Re: SPID question
i like the olive green but wasent there more than one shade? if so how can i tell which my truck had?
Old 06-30-2009, 09:43 PM   #4
tcb-1
tcb-1's Avatar
Re: SPID question
you're in luck. I checked my build sheet for my '69 is "534" olive/green as well. the code for the green origianlly on your truck is going to be 504 "yellow green poly".
Doug
