Old 07-02-2009, 06:21 PM   #1
80chevyshortbox
80chevyshortbox's Avatar
coil cut???
hey i am just wondering if there is a way for me to cut my front coil with out having to pop my A arm. i am wanting to lower my truck more. so i just thought maby there is an easy way to do it. any way if i cant w/e it dont matter. thanks
80chevyshortbox is offline   Reply With Quote
Old 07-02-2009, 07:19 PM   #2
blown luv
Re: coil cut???
Yes it can be done.I did a 84 about 10 years ago. We placed a jack on the engine crossmember and jacked it up so both tires were off the ground about 3". Used a torch and cut 2 coils off.Pulled out the 2 coils and let the jack down. This really lowers the front. Had to add alot of shims to get the wheels straight up and down. They leaned way in at the top.
blown luv is offline   Reply With Quote
Old 07-02-2009, 08:54 PM   #3
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: coil cut???
Just like he said, just cut one coil at a time and test it then if you think it need to go lower just cut 1/2 of the next one.
tvblazer78 is offline   Reply With Quote
Old 07-02-2009, 09:09 PM   #4
S10Fan
Old Heap Driver
Re: coil cut???
Keep in mind that various trucks have different springs, age of springs, engine combinations that have different weights. My 250 6 cylinder 3 speed truck dropped one inch after i cut exactly one coil, yours may be different. I highly recommend you take out the spring to do any cutting. Sure, it's an all afternoon job, but I see all sorts of red flags trying to torch one while it's installed. That's coming from a guy that has lost 2 friends to burn injuries while they were using torches on a car/truck.
Correction!!! My truck dropped 3 inches with cutting one coil.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 07-02-2009, 10:02 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: coil cut???
that sounds dangerous cutting coils in the truck with a torch and I agree to s-10 fan, I would take the time and take out the coil and cut
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-02-2009, 10:16 PM   #6
80chevyshortbox
Re: coil cut???
thanks for the advice guys. idk if im gona do it thoigh cuse i all ready have drop spindal's, shackels and one leaf out of each side out. so im just gona wate see how i likethe stance when the motor and the box goes back in then if i still dont like it all take out another leaf and cut the coil and do the job the right way.
thanks agen
Old 07-02-2009, 10:29 PM   #7
bigblock73
yeller
bigblock73's Avatar
Re: coil cut???
You should NEVER cut a spring with a torch, too much heat, it will affect the spring integrity. Use a cut off wheel for better results. I also suggest removing the spring as opposed to doing it with it in the truck.
bigblock73 is offline   Reply With Quote
Old 07-02-2009, 10:40 PM   #8
dammitmitchell
the pollock
dammitmitchell's Avatar
Re: coil cut???
serioously....rent from autobone a spring compressor.... then do it the "right way" because a accident with a spring can kill you..
period...
please dont half ass something like that.. im genuinely concerned for your safety on this one..
plus.. if you have both out of the truck you can double check and grind a "smooth" lip onto it so they sit nicley into the spring cups..
thus preventing unnecessary wear on the parts...
or save money and buy shorter springs.....
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 07-03-2009, 01:11 PM   #9
80chevyshortbox
Re: coil cut???
ya if i do it i will make it a weekend project and all do it the right way.
Old 07-03-2009, 02:25 PM   #10
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: coil cut???
with the cheap cost of coil springs why not just buy a set of lowering springs... i mean hey i cold save $30 on jack stands by using a couple of 2X4s but hey... know what i mean?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
