Rivet Removal: What Are Your Best Tools & Techniques?
Fellas,
I need to remove some rivets from my frame. I'd love to know what the Nation has found to work well for this type of task. Post what you do (or even what you heard your sister's boysfriend's, step-dad's uncle -- twice removed -- did). thanks. War Chevy ![]()
broke d!@k dog Garage ![]() 1969 C20 - Project: "Big Sexy" [http://67-72chevytrucks.com/vboard/s...d.php?t=454894] 2003 'Burban - [Big Pop's daily driver] 1969 350/350 Stingray - [as soon as the economy turns...] 1939 Chevy Roadster Pick Up - Project: "Pre-School" (searching now) |
The Older Generation
Re: Rivet Removal: What Are Your Best Tools & Techniques?
I just use a BFH and a chisel sharpened on one side. It seems to pop the heads off easier. Be sure and hold the chisel with Vise Grips and wear safety glasses and gloves.... LockDoc
My Carbon Footprint
I hope someone will agree with me on this so I don't sound like I'm full of S**T but I like to use my cutting torch. Once you get good with one of those, it's like an artist and a paint brush. You can get the rivot hot enough to blow away with the oxygen but it wont affect the frame.
My 2nd choice is the air chisle...not good on fillings in the ole molars though. Last edited by prostreetC-10; 07-02-2009 at 08:47 PM. |
#4 | |
Worthless
Grind the head off and pop out..seems to work easiest for me..
Bob |
#6 | |
LockDoc
grind an "X" on the head with a cutoff wheel.. then use an air chisel to nip the four pieces right off... sometimes I had to use the air chisel with a punch installed to knock it out then... Didn't mess up the metal at all..
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
That's a great idea. I have to take the rivets out of the front crossmember to install my swaybar - I think that's the way I'll do it. Only thing I'm nervous about is that the gas line is only a couple of inches from the rivet - I'm gonna have to protect it somehow.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Proper way to remove any rivet. Get a bit 1 size smaller than the shank drill straight down thru the top of the rivet head, just deep enough to loosen the heads grip. Then center punch the grip out from the top. Common method is to grind the entire head almost flush with a grinder then tap it thru with a punch or drive pin.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
I agree with msgross. I use an 1/8 thick cutoff wheel to cut an X in the rivet head. I use a double X as it takes less time to grind the x and the "pie slices" pop off easier when you hit them with the chisel. Good luck with the removal. I ran into a situation where the plates were not tight together and the rivet had bulged and/or shifted between the plates so even after cutting off the heads I had to do some prying and hammering to get the plates to separate as I could not drive the rivet out due to the bulge/shift.
![]() Join Date: May 2007
Did you learn to hold it with a vise grip the hard way like i did? LOL!!!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#12 | |
![]() LockDoc
I like to drill them out. With cobalt drill bits, it seems to be the quickest easiest,way with the least chance of damaging anything.
Member #1049
I use a cutting torch to "wash" the heads off.. (Be careful with a torch, if your not vary handy with one its probably best to use a different method as there is a fine line between "washing" the heads and cutting/damaging everything)
Next I use a grinder to make them completely flush.. then pop em out with an air chisel punch |
#15 |
woodman13
![]() Join Date: Jul 2004
Plasma cutter
Woodman13 2007 Dodge Ram 3500 5.9 rolling coal! 1994 Caprice 9C1 88K miles, LT-1, dropped/shaved 1967 C-30 350 4 sp dually 1971 C10 SWB BBC, auto; good driver |
#16 |
Loving the Jimmster
Sawzal with a metal blade and an air grinder
#17 | |
Next project: 1970 K10
Or I'll just blow the center out with the plasma cutter, and a quick tap with the hammer and they fall right out.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#18 |
My Carbon Footprint
#19 |
woodman13
Sorry, picked it up at a DOL on a pallet sale 2 years ago for $180, new in the box along with a Lincoln welder and a Miller portable Bobcat gas welder. ![]()
#20 |
I agree with the drill out method. (some industries it's the ONLY approved method) And use a center punch to get yourself started if there isn't already a dimple there.
#21 |
![]() Join Date: Apr 2007
angle grind the head off, center punch it and drill it out. easy.
every air chisel Ive had had died on me mid way through the job!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 07-03-2009 at 03:33 PM. |
#22 |
Strongman Garage
![]() Join Date: Apr 2000
a hammer and a chisel seriously works? I couldn't imagine, it takes long enough with an air chisel!
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
#23 |
Devil's in the Details
Oxy/Acetyl torch is what I used to remove the rivets through the frame on my rear shackle brackets. Get the mix right and it is a quick process. Just don't drip any on yourself.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
#24 |
68 just like me
on areas that you can get to I have had real good luck with a sawzall laid on its side
68 just like me ![]() |
#25 |
I just bought a nice set of rivot removal drill bits from harbor freight that work like a charm. Drill the shaft from the head side and they fall out, no chisel or hammers needed. It is a pain sometimes to get the head back off the bit if you drill to deep.
