Old 07-03-2009, 12:19 AM   #1
TK56
fuel injection engine anyone??
I'm trying to get my 56 chevy pickup road worthy just got the c4 IFS and probably going with a 12 bolt rear and I have a built up 700r4 all I need to address is the Cab (cab corners, steps/rocker panels, the usual places) , and an engine. I have all the other parts to get it on the road. Im lookin to get a fuel injection engine maybe out of a silverado or LT1. LS motors are out of my price range for now. what efi motors would you guys recommend using and maybe have experience with?
TK56 is offline   Reply With Quote
Old 07-03-2009, 07:15 AM   #2
blackdiesel
blackdiesel's Avatar
Re: fuel injection engine anyone??
Well, I think the LS is the way to go, I really think if you look around that you can get one for 3k. Saying that I just put a LT1/4l60e in my 38 coupe. And I am well pleased with it. The motor had been pulled in 98 out of a 97 vette with 23k miles on it. sence the last year for the LT was 97 it might be hard to find one with low miles. You can't build a SBC that will run or get close to the fuel milage of the LT'S or LS'S for any were close to the price of it. just my .02
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 07-03-2009, 07:57 AM   #3
Atomsplitter
Atomsplitter's Avatar
Hey TK56,
I'm running a 1995 Impala SS LT1 (about 100,000 miles on it), a 700R4 and I paid $500 for the motor transmission, computer, wiring harness, cooling fans, fuse block, etc, etc - basically everything from the engine bay. As Blackdiesel stated these may be hard to find with low miles and they are expensive to rebuild but they get excellent gas milage and are very reliable. Just price out the Optispark distributor and Water pump for example. As your probably aware these LT1's & LS engines, and I'm talking specifically about the "Sequential Port Fuel Injected" produced from 1994 were found in Caprice Classics, Impalas, Fleetwoods Camaros, Firebirds and of course Corvettes. These motors at least from 1994 and newer were a quantum leap forward from the the previous TBI units, just check out the specs for power and gas mileage between 2 similar cars. They went from 180hp to 260hp and got 26% better gas milage in the Caprice/Impala.
If I had to do this by myself, with my limited knowledge of computer control, I would have gone old school with a carb but my friend who is a GM electrician has the lap-top computer to reprogram the ECM and help me get the correct electronic feed to my speedo to make it all work.
Atomsplitter is offline   Reply With Quote
Old 07-03-2009, 04:55 PM   #4
TK56
an LS1 would be the ultimate way to go ! but I dont have that kind of money right now !
did you guys use an after market harness and computer??
Old 07-03-2009, 06:28 PM   #5
54 jimmy
54 jimmy's Avatar
you could try this company if you have a carb motor might be in you price range www.affordable-fuel-injection.com
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 07-03-2009, 07:41 PM   #6
mbgmike
I know its not newtech but a buddy of mine has 8 of the old mechanical FI units complete off the old 57 chevys. Might look cool since not many around
This is not a pic of them but its what they look like
mbgmike is offline   Reply With Quote
Old 07-03-2009, 08:20 PM   #7
hotrodsbyray
mbgmike,
That is one neat looking unti!
I don't mean to hijack the thread but I would love to get one of those injection units! Even if it wasn't functional, you could at least adapt a throttle body to the intake and it would have that look.
Sent you an email at the earthlink address
hotrodsbyray is offline   Reply With Quote
Old 07-04-2009, 08:05 AM   #8
blackdiesel
I used a harness from haywire, 550 bucks and it runs the 4l60e also. If you want motor only it 450. It's by far the easiest way to go. They even take care of the VATS for you.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 07-04-2009, 08:13 AM   #9
50adrod
50adrod's Avatar
then you need to go with a 5.3 from a later model truck or tahoe. the 5.3 is basicly an iron block LS1 and can be had for less than 1K, check ebay or your local salvage yard, they are very plentiful. get the harness and computer from the donor also. the newer 5.3's will do around 325 hp bone stock and they respond very well to mods. a cam. header and a tune and you will be close to the 400 hp mark. plus great diveability and fuel mileage. you can folow the link in my sig to see mine. good luck
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 07-04-2009, 04:03 PM   #10
cajundragger
you find ls1's for $900 often.
ebay harness for 380ish plus a computer. I forget exactly what year but I think a 2001 s-10 computer can be reflashed to run an ls1. which saves lots of money.
there no other way you can get 300 wheel horse power any cheaper and keep it OEM reliable.
cajundragger is offline   Reply With Quote
Old 07-04-2009, 07:36 PM   #11
TK56
anyone seen the 6.0L LQ4 or LQ9 in a hot rod ??
those make some serious HP with just a cam and headers !
Old 07-04-2009, 11:05 PM   #12
50adrod
50adrod's Avatar
yes, someone on this board has done one in a AD truck
