Old 07-03-2009, 02:17 AM   #1
cppursell
cppursell's Avatar
Exclamation Turbo Hydra-matic tranny speedometer not working
Hi everyone, I'm hoping you can help my dilemma.
Ever since I've had my '67 Chevy C10, the speedometer hasn't worked.
I'm pretty sure I have a 350 Turbo Hydra-matic transmission.
I looked under the truck and I noticed that the speedo cable is attached to this box-looking device which connects to the transmission. I thought that was just a third-party gear reducer or something, but it seems to be part of the transmission, 'cause if I take that away, there's no way to directly connect the speedo cable to the tranny. Looking at the box-thing, there seems to be a missing part inside the end that plugs into the tranny, and that's probably why the speedometer doesn't work.
Are you familiar with this box device, is it part of the transmission, how can I fix it?
I hope I was clear enough...
I don't know what I need to get the speedometer working, but if you can give me any pointers, that'd be great.
Thanks!
cppursell is offline   Reply With Quote
Old 07-03-2009, 08:06 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: Turbo Hydra-matic tranny speedometer not working
First welcome from NC...to the best board on the internet!!!
here ya go...this should be a great help to you! http://67-72chevytrucks.com/vboard/s...d.php?t=345091
You may need to change the speedo gear housing gasket or the housing and the driven gear....good luck
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-03-2009, 01:37 PM   #3
cppursell
cppursell's Avatar
OKAY! I notice on that great article you sent me to, that my box converter thing replaces the original speedo thread connector! Okay, so I just need to get one of those original connectors, get the speedometer working again, then determine what gears I need to adjust.
Thanks for your help gcburdic!
cable, gear, speedometer, transmission
