Old 07-07-2009, 11:21 PM   #301
highperf4x4
Re: And so it begins................
Ok, I'm troubleshooting the A/C now so I'll have to get back to the body work later. For some reason it decided to stop cooling even though it isn't low on freeon. If anybody knows someone with experience in dealing with POA a/c systems let me know.
highperf4x4 is offline   Reply With Quote
Old 07-07-2009, 11:45 PM   #302
70 Suburban
Rods
i would start by layin hands on it.. realy grab the lines. make sure there is no sudden temp drop. do the same on the condensor. make sure that there is nothing blocking the evap.. thats where I would start. then leme know what your pressures are. Is your compressor cycling or is it staying off, or on...
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 07-08-2009, 01:04 AM   #303
highperf4x4
That's the thing with a POA system, the compressor doesn't cycle. It just stays on. I haven't been able to check the high side pressure yet but the low side was reading about 25psi
Old 07-08-2009, 07:01 AM   #304
70 Suburban
Rods
the compressor will cycle if there is to little freon or if the pressure on the high side is to high it will shut the compressor off. pressure will drop then it will come back onl. It looks like cycle.
Old 07-08-2009, 08:20 AM   #305
joe231
joe231's Avatar
25 on the low side is pretty low, it needs to be at least 35-40...
BTW, what is POA?
oh wait....are you running R-12 or R-134? that makes a difference in pressures.
I have seen the compressor go bad and it would still run but it would not build any pressure on the high side.
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-08-2009, 08:23 AM   #306
JohnC
JohnC's Avatar
That's a Hyperism Joe. Guess he need's to have a quick guide for us!
Man I wish I knew more about A/C. Is it still the old R12 system, or have you converted to 134A?
JohnC is offline   Reply With Quote
Old 07-08-2009, 09:07 AM   #307
70 Suburban
Rods
Poa should be about 28-30 max.. But you can update it to ccot
Old 07-08-2009, 09:07 AM   #308
70 Suburban
Rods
If you are running 134 did you adjust the poa?
Old 07-08-2009, 09:39 AM   #309
joe231
joe231's Avatar
oh, found some info
Originally Posted by youracauthority.com
Pilot Operated Absolute (POA) Valve
Like the suction valve, the POA valve is a suction throttling device that is located at the outlet of the A/C evaporator and is used to control the amount of compressor suction on the evaporator.
The POA valve was used on some General Motors and Ford air conditioning systems through the 1970's. On these A/C systems, the compressor would run constantly whenever the A/C system was on. Under certain operating conditions, less compressor suction was required on the evaporator. The POA valve would then close off the flow of refrigerant, effectively reducing the amount of compressor suction.
Cycling Clutch Orifice Tube - CCOT A/C System
General Motors introduced the cycling clutch orifice tube A/C system in the 1977 model year. The unique advantage to having a cycling clutch with a fixed orifice tube was that now, the only moving part on the A/C system would the A/C compressor. The fixed orifice tube, which provides a one size, fixed opening for the flow of refrigerant into the expansion valve had replaced the typical expansion valve or TXV valve that opened and closed to control the refrigerant flow into the evaporator.
The fixed orifice tube means that there is always a flow of refrigerant into the evaporator. In order to control the evaporator pressure and maintain the coldest possible temperature in the evaporator without freezing the condensation, the system was designed to cycle the compressor on and off.
The cycling clutch system meant that the typical normal pressure gauge readings of a properly operating system would have a wider range. Of course, the low side pressures would be at their lowest just before the compressor cycles off while the high side pressures would be at their highest. As soon as the compressor clutch disengages, the high pressures start to drop while the low pressures increase. That happens because the fixed orifice tube is always allowing refrigerant to flow through it, regardless of whether the compressor is on or off. As soon as low pressures began to rise causing a higher temperature in the evaporator, the compressor would cycle back on to pull the pressures and temperature down on the low, once again increasing the pressures on the high side. The cycle continues in a controlled manner that maintains mean or average pressures in the evaporator so that the A/C system can provide maximum cooling performance with the minimum number of moving components.
Understand that the CCOT or fixed orifice tube system is still slightly different than typical cycling clutch systems. In other system designs, expansion valves are still used to control the flow of refrigerant into the evaporator. Those typical expansion valves open and close to monitor refrigerant flow while the compressor cycles on and off to maintain proper evaporator pressures. The orifice tube system utilizes the fixed opening in the orifice tube which maintains a constant flow of refrigerant.
so it sounds to me like your POA valve might be malfunctioning?
CHEVY ONLY
Old 07-08-2009, 11:54 AM   #310
mrein3
mrein3's Avatar
IF everything else is working right, and IF you are still running R12, you need to add some. You should be in the 28-30 range.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 07-08-2009, 03:00 PM   #311
JohnC
JohnC's Avatar
Great info Joe!
Old 07-08-2009, 08:44 PM   #312
TheSebring
Trying breaking off the line to the condenser and see how long it sprays everywhere. If it sprays for over a minute, you HAD plenty.
TheSebring is offline   Reply With Quote
Old 07-08-2009, 09:45 PM   #313
joe231
joe231's Avatar
that method is not for the feint of heart
CHEVY ONLY
Old 07-09-2009, 01:14 AM   #314
highperf4x4
You guys are killing me........
Old 07-09-2009, 01:22 AM   #315
highperf4x4
Mine has never shut off on it's own. I turned it on empty after I installed the compressor and it engaged, I had to shut it off and add the oil charge before I turned it on again. You got any idea where the low pressure shut off should be?
BTW, what is POA?
I'm running 134 in it. I don't even get 35-40 on my 4x4 though and it's r12 unless you're talking about after it cycles off and then it climbs to about 55. However, the 72 doesn't cycle.
I wish you knew more too!
I"m thinking about making the switch. Have you done it before?
It was a redneck adjustment. I took the valve out and turned it counterclockwise a half turn! I know, ..... don't say it.
oh, found some info
me thinks so too.
Not running r12 but it was reading 25 even before I adjusted the POA. I won't know what it is now until I charge it again tomorrow
Stay away from my truck.
Old 07-09-2009, 08:07 AM   #316
JohnC
JohnC's Avatar
Not everyone has your method of trouble shooting!
That's why I'm here is to learn. Teach me grasshopper!
Old 07-09-2009, 12:20 PM   #317
highperf4x4
I will just as soon as I figure it out. New compressor just locked up so you may want to learn from someone else.....................
Old 07-09-2009, 01:09 PM   #318
joe231
joe231's Avatar
ouch, that sucks
CHEVY ONLY
Old 07-09-2009, 01:48 PM   #319
scotts62
One day...
scotts62's Avatar
Scream WARRANTY!
Scott
93 crew cab build
Project 62
Old 07-09-2009, 03:05 PM   #320
TheSebring
I'll tell you what, it may be an unorthodox way of trouble shooting, but I figured out that it had plenty of freeon. So it works.
Old 07-09-2009, 04:36 PM   #321
JohnC
JohnC's Avatar
that you did Blake that you did.
Old 07-09-2009, 08:10 PM   #322
highperf4x4
The only thing you flippin figured out is where the SECOND leak is. Now go polish some wheels!
Old 07-10-2009, 08:04 AM   #323
JohnC
JohnC's Avatar
Ah those priceless Father Son moments!
Old 07-10-2009, 07:42 PM   #324
TheSebring
Priceless my butt.
Price of 4 barrel intake:200
Price of 4 barrel Edelbrock carb:300
Price of a new spare because the old one was used to try and tighten up new lug studs(and the old one was the FACTORY):100
Old 07-12-2009, 03:55 PM   #325
highperf4x4
Priceless my butt.
oh bull crap. Go to a flippin mopar forum and tell them you need one of the old 5 lug 14" wheels and they will give 10 of them for free. I threw the other 4 from this car in the trash years ago.
