Old 07-09-2009, 05:14 PM   #201
ndametz32
Fire Truck
ndametz32's Avatar
Re: No Regrets - The Rebuild post
Not a fan of chopped tops but I must say that looks SICK! Keep it up man!
-Nick
'83 Chevrolet Silverado Stepside
http://67-72chevytrucks.com/vboard/s...d.php?t=349394
ndametz32 is offline   Reply With Quote
Old 07-09-2009, 11:05 PM   #202
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Originally Posted by youngrodder View Post
Who welded up your stainless exhaust? Anyone local?
Hey Marc how it going? I had Jeff over at Michigan Exhaust do the pipes. He actually came through with the pipe itself for a pretty good price as well.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-09-2009, 11:16 PM   #203
evan
evan's Avatar
Very cool. What are you doing for a gas tank?
Evan B.
evan is offline   Reply With Quote
Old 07-09-2009, 11:29 PM   #204
smashingchuck
Thanks. I agree that usually this style truck doesn't look right chopped, but for some reason mine does.
Not sure yet... I have a stainless fuel cell from before, but I would really like something a little more "stealthy." Unfortunately "stealthy" and "low cost" don't seem to jive. No matter what, it unfortunately has to be mounted in the bed... I'm out of safe places to mount it on the chassis.
78 Build Thread
4Runner Build
Old 07-12-2009, 08:09 PM   #205
smashingchuck
I spent most of the weekend (Friday and Saturday) at Pinks All Out, I saw a lot of really nice cars.
Anyway, Sunday I was able to get a little tinkering done. First I finished up the new and still needing improvement upper radiator support bracket. I got a little happy and drilled the mounting holes in it before I test fit the shroud and... well they need to be moved back about 3/16" of an inch so the bracket has enough overhang to let the shroud lay flat on the radiator. I also figured out that the aluminum radiator I had bought had a pretty nasty bend in it from shipping, but was able to straighten it out by strategically placing some blocks of wood on the shop floor and standing on the opposite corners of the radiator. Other than that, things look pretty groovy.
I also got busy on making the brackets that hold the A/C condenser. I think they turned out pretty good, considering Hot Rod Air supplied some glorified plumbers tape to accomplish the same job.
78 Build Thread
4Runner Build
Old 07-12-2009, 11:37 PM   #206
joe231
joe231's Avatar
nice work!!
looks good!!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-13-2009, 06:38 PM   #207
bigbadjohn84
hey, how are you retaining the AC on your truck? your bagging it right? or am I wrong? just curious. I want to bag mine and Z the frame. but I WANT AC lol
Edit... looking back I see its bagged now... DOH!! anyways.. AC?
bigbadjohn84 is offline   Reply With Quote
Old 07-13-2009, 07:34 PM   #208
flamingbig10
6.0 powered square
flamingbig10's Avatar
he's using a under the dash a/c unit
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-13-2009, 08:57 PM   #209
bigbadjohn84
ah.. that bites.. i saw where one guy on here had his blower assembly relocated upward to allow room and retain ac.. I was hoping to find more pics of resources on how this is done.. the under dash ac is cool.. lol. but mine is a low buck project. granted Im gonna do some big things, just wanna do my best to make it stock feeling while layin out lol
Old 07-13-2009, 09:41 PM   #210
tvblazer78
Low & Fast!
tvblazer78's Avatar
Nice work man!
tvblazer78 is offline   Reply With Quote
Old 07-13-2009, 11:26 PM   #211
smashingchuck
Well if your truck has A/C from the factory you're half way there. You won't need to buy a condenser, a drier, or a compressor. You will need new lines, the under-dash unit itself, and the controls. I think the units are about $400 and some change though summit. It doesn't get much more low buck than that.
78 Build Thread
4Runner Build
Old 07-18-2009, 07:11 PM   #212
smashingchuck
---Saturday---
I got the electric fan mounts made and it seems to fit pretty nice. I used a Jeep Grand Cherokee fan from moparpart.com. I also got the catch can mounted and I'm starting to look at my inner fenders again... I never finished them completely and they still need some "massaging". After I get the inners mounted again I can start checking out where I'm going to put the A/C bulkhead and finally hang the Hot Rod Air "box" inside the cab.
78 Build Thread
4Runner Build
Old 07-18-2009, 09:23 PM   #213
cochino12
It followed me home?
cochino12's Avatar
Originally Posted by smashingchuck View Post
---Saturday---
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-18-2009, 10:28 PM   #214
bigbadjohn84
400? not bad. I amy look into that for sure. I want mine to lay low. that would open up wheel choices for me as well your truck is coming along great man! can't wait to see the finished product
Old 08-07-2009, 10:07 AM   #215
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Any updates?
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 08-07-2009, 12:34 PM   #216
smashingchuck
Originally Posted by dieselarmy13 View Post
Any updates?
Been working on the house.
78 Build Thread
4Runner Build
Old 08-08-2009, 11:04 PM   #217
OrangeAnimal
OrangeAnimal's Avatar
Hey Smashing I see you are working on the A/C I got mine almost done. Good luck on using the bulkhead fitting. I was going to try that but there just wasn't enough space. Also I was sorta in alittle bit of a time crunch. It get ice cold in there now though.
There are some pics of it in my thread. Your truck is looking pretty sweet. Keep it up!!
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 08-20-2009, 07:03 PM   #218
Zman86
Zman86's Avatar
Truck looks great! Reminds me of mine, except better in every way possible. I'm scared to start stripping the my cab, fearful of what I might find with the chopped roof, and my doors are in hideous shape/aligned terribly. The gaps/lines are all over the place over basically the entire body. Seeing yours all lined up though definatly makes me want to get crackin on the bodywork with mine, cant wait to see the final product
'75/'81 Chevy C-10 project... Hitting the streets Spring '10....
Cardomain Page http://www.cardomain.com/ride/3371894
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=357953
Zman86 is offline   Reply With Quote
Old 08-20-2009, 07:27 PM   #219
smashingchuck
Thanks Zman. I plan to get cracking on it again this fall. I had to take a break so I could do some much needed renovations on my house. I had to tear down a chimney that passes through three different roofs, replace a window, and make all the trim. The final outcome is to make it look like it was never there, so I have to reside it as well. My house is 100 years old, which means all dimensional lumber that we are used to now is too small, so I have to buy all oversized pieces and plane and rip it down to the desired size. It's only slightly time consuming. I'm half way there.
78 Build Thread
4Runner Build
Old 08-20-2009, 07:53 PM   #220
bigblock73
yeller
bigblock73's Avatar
OK, pics of the house are in order now!
bigblock73 is offline   Reply With Quote
Old 08-20-2009, 09:48 PM   #221
joe231
joe231's Avatar
maybe i missed it...what is the fan shroud out of?
CHEVY ONLY
Old 08-21-2009, 01:11 PM   #222
smashingchuck
It's a stock replacement from LMC.
Don't have any of the work getting done, but here's a shot from this spring.
78 Build Thread
4Runner Build
Old 08-21-2009, 01:34 PM   #223
menace121978
menace121978's Avatar
whoa! thats beautiful!! no wonder the trucks slowed down...
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 08-21-2009, 01:40 PM   #224
dieselarmy13
Originally Posted by menace121978 View Post
whoa! Thats beautiful!! No wonder the trucks slowed down...
x2!!
Old 08-22-2009, 10:55 AM   #225
Bazooka
Keepin it old school
Bazooka's Avatar
That is a beautiful house..
Bazooka is offline   Reply With Quote
