07-12-2009, 09:39 PM | #1 |
Restoration Virgin!
Valve cover gaskets and hold downs
So I finished polishing these up and want to know which VC gaskets and hold downs I should use....they are aluminum VC....(I have spreader bars and long T-bars, but wasn't sure if I should reuse those??)
Thanks for your input!!!...Geoff
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
07-12-2009, 09:55 PM | #2 |
Alright Alright Alright
Re: Valve cover gaskets and hold downs
I dont think youll need to use spreaders. Those valve covers are thick casted and the are designed better.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies |
07-12-2009, 10:45 PM | #3 |
Junior Member
Yeah, what he said. Also, you can use regular gaskets. Just don't tighten too tight; could crack the valve cover. Cast covers seal so much nicer than the stamped stuff.
"A man's got to know his limitations." - Dirty Harry _______________________________________________ 1967 C20 Custom Camper, 327, Powerglide, PS, PB, No-Spin Locker |
07-12-2009, 11:53 PM | #4 |
i use high dollar ones that have copper in it.. they are blue rubber with the copper or whatever in them its about 40 bucks for them they are reusable
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
07-13-2009, 09:33 PM | #5 |
Restoration Virgin!
Thanks for the input...I picked up some Fel Pro Perma Dry Plus (part #VC12869T)...
these things are stout!!...Silicone around a steel core....Paid $32 for them at NAPA....
07-13-2009, 09:46 PM | #6 |
Moderator
gcburdic- You bought the correct gaskets. You will not be disappointed with those.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
07-13-2009, 11:01 PM | #7 |
Just lettin ya'll know Napa carries a cork gasket that is twice as thick as the normal ones they stock for a SBC. You have to ask for them and they are only about 12 bucks. I know there are others out there like me that just will never use anything but cork. just a little extra info that is all. I know which gaskets you bought and they are definitely some quality gaskets. Don't want anyone to think I was knockin' them.
'72 Chevy C10 383, 700r4, 3.73's A little rust never hurt anyone. I consider it weight reduction. |
07-14-2009, 01:06 AM | #8 |
the perma dry was what i was talkin about.. i got them on my dads mustang.. best ones i ever uses.. didnt even need adhesive
07-14-2009, 07:48 AM | #9 |
72 GMC
those look like the covers on my truck.
the flange was just enough thicker that my stock bolts would not reach. might want to check that before you start with the rtv. |
07-14-2009, 08:06 AM | #10 |
Agree on the Perma Dry. Put them on mine and no more leaks.
07-14-2009, 09:08 AM | #11 |
Between Trucks...
Nice valve covers. I think Summit has aluminum t-bars, chrome ones might look a little off next to the aluminum. Studs and nuts would look good too.
Beat it to fit, Paint it to match... Last edited by Sinister; 07-14-2009 at 09:09 AM. |
07-14-2009, 11:36 AM | #12 | |
Restoration Virgin!
Thansk Sinister....I'll check it out!!!
07-14-2009, 11:56 AM | #13 |
Watch out for your cornhole !
I always figured those t bolt quick release fasteners kind of implied that I was always having to work on my engine.
BTW, Permadry gaskets are the best. I've used the same set on several engines.
07-14-2009, 12:54 PM | #14 |
70 Chevrolet=Obsession
I used Mickey Thompson cast aluminum covers on my SBC and the extra thick gaskets from Napa. I bought a tube of Permatex no.2 soft gasket gunk and applied it to both sides and installed them. My covers didn't even come with spreaders as I think only pressed steel covers use them. One thing though, After I tightened the wing style bolts down the next day I found them fairly loose. I retightened them repeatedly for the next few days and now they are nice and tight and no leaks!
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
07-15-2009, 09:09 PM | #15 |
Restoration Virgin!
So I installed the VC and gasket, but passenger outside between the t-bars it leaks some.....any idea what I need to do to make it seat better.....I didn't think I should use gasket gunk???...It even says not to on the box???...Thanks
07-16-2009, 11:10 AM | #16 |
Did you use the spreader bars?
I had a leak on my driver's side and decided to use some RTV and that did the trick. I suspect that I may not be able to re-use that gasket though... |
07-16-2009, 01:02 PM | #17 |
Restoration Virgin!
Nope...didn't use the spreaders....I'll check to see if the t-bars are bottoming out and not seating on the gasket tonight.....may go w/ the rtv if all else fails!!!
07-16-2009, 01:10 PM | #18 |
There is something wrong then. Felpro designed those gaskets to be installed without sealer. I have a pair of them on different engines and even different valve covers and never a leak without sealer. When I blew up the engine, I took the ARP bolts and the permadry gaskets off of it before I scrapped it and used them again on the next engine. I put 100k miles on the next engine.
Either your valve covers are warped, there is some foreign matter on the head where the gasket seats, or the bolts are bottoming out in the holes before the cover is cinched down.
07-16-2009, 01:19 PM | #19 |
Restoration Virgin!
Thanks TX FF....I did have the VC on a flat surface to make sure they weren't warped when I bought them....I did check/ wipe the lip of the head before installing the gasket....so the last thing I need to do is check for the bolts bottoming out (I hope this is the case)....can you recommend better hold downs (I definitely don't like the t-bars)...you mention ARP...where can I get some??
07-16-2009, 01:25 PM | #20 |
I get all my parts from Summit.
07-16-2009, 01:42 PM | #21 |
In my case it was the VC (cheap Edelbrocks) and not the gasket itself.
07-16-2009, 06:07 PM | #22 |
Restoration Virgin!
ah ha....these will work...thanks TX FF....http://www.summitracing.com/parts/ARP-400-7507/
11-15-2009, 02:52 PM | #23 | |
11-15-2009, 05:08 PM | #24 |
What kind of gaskets did you use? If you used cork, did you RTV them to the valve cover?
11-15-2009, 05:19 PM | #25 |
I used Fel Pro Perma Dry Plus rubber ones
