Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 07-13-2009, 07:34 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I need some power
I just bought two kicker comp 12'' subs for my blazer what would you recommend for an amp... And maybe where to buy it...
Model C12
Size (IN.,CM) 12, 30.5
Impedance (OHMS) 4 or 8
Max Rec Amplifier Power (WATTS PEAK/RMS)* 300/150
Sensitivity (dB 1w/1m) 89.1
Frequency Response (Hz) 27-500
Mounting Depth (IN.,CM) 5-13/16, 14.8
Mounting Cutout (IN.,CM) 11-1/8, 28.3
Min Rec Sealed Box Volume (CU. FT., Liters) 1.25, 35.4
Max Rec Sealed Box Volume (CU. FT., Liters) 3.5, 99.1
Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 2.25, 63.7
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-14-2009, 02:36 AM   #2
AceX
>130dB Moderator
AceX's Avatar
Re: I need some power
Arc Audio just launched a new line of Class-D amps that are competitive with anything out there.
The XXD1500 would be perfect for this job.
http://store.arcaudio.com/product/pa....58862.0.0.0.0
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
