07-16-2009, 10:43 AM | #1 |
Between Trucks...
How do you Remove Factory AC?
I have the inner fender dropped, undid all the nuts on the front of the unit. Seems to be attached to the stuff in the cab, doesn't want to come out. I want this stuff gone so I can shave my firewall.
Beat it to fit, Paint it to match... |
07-16-2009, 11:36 AM | #2 |
Between Trucks...
Re: How do you Remove Factory AC?
O.K. got it, I had missed a nut. Any tips for getting the inside the cab part out?
07-16-2009, 12:15 PM | #3 | |
If that is true, you need to find the nuts on the outside of the firewall, remove them, remove the heater hoses, and pull the unit, spilling antifreeze all over your interior.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
07-16-2009, 02:04 PM | #4 |
Between Trucks...
I got the engine bay part out. Doesn't look like there any more nuts or bolts on that side. Taking a break now, it's like a 100 degrees here.
07-16-2009, 06:36 PM | #5 |
are you putting vintage in?
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
07-16-2009, 06:46 PM | #6 |
Between Trucks...
I'm going to eventually. Trying to decide if I'm gonna start on a motor first.
Beat it to fit, Paint it to match... Last edited by Sinister; 07-16-2009 at 06:46 PM. |
07-16-2009, 06:50 PM | #7 |
425hp409
You guys that are installing "Vintage Air", should also look at "Old Air Products" in Ft. Worth TX. www.oldairproducts.com They are really good guys to work with and have an excellent unit that I have put in quite a few of my customers cars and trucks.
Charles 68 SWB, Dad bought new, now 396 & factory ac 64 Impala SS, 409 425HP, 4 speed AC 64 Bel Air Wagon, 400 Small Block 57 Bel Air all original 283 w/Factory Air 77 GMC Sprint, 454/425HP 67 Olds 442, all original 90 ZR1 Corvette |
07-16-2009, 08:28 PM | #8 |
sharp as a marble
I just removed my factory air from my 72 Blazer. I was able to get all of the stuff out of the engine compartment without pulling the inner fender panel, or the hood and hinge. There are a couple of fasteners inside the cab, the will be visible when you remove the glove box.
