Old 07-17-2009, 06:30 PM   #1
mxriderae
20 " wheels for the 72
i haben`t started on my truck yet but found a set of wheels .. 20"
can i fit them on the truck without cutting or modifications .. am planning to fit an airride or drop kit .. so is it going to work with the 20" wheels ??
thanx
they are 20 x 8.5
+14 mm offset
mxriderae is offline   Reply With Quote
Old 07-17-2009, 06:38 PM   #2
SBC
SBC's Avatar
Re: 20 " wheels for the 72
Welcome to the board!! I have a 3/5 drop on my truck with 22" wheels and didn't do any modifications. With and airbag suspension i think you just have to c-notch the frame to get it low but the guys on here with bags can help you more.
1967 C-10 Project
2008 Suburban
2017 GMC Sierra
SBC is offline   Reply With Quote
Old 07-17-2009, 10:51 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
mxriderae, glad to have you apart of the board. You will be able to run a set of 20's with much modification, and a c-notch will not be required; it all depends on how low you want to go.
In terms of BS (backspacing), each truck is designed differently than another so be sure to measure once, and then measure 3 more times.
For instance, I could provide you BS for a 67-70, but the rearends are narrower than the 71-72 rearends. Depending on whether or not disc spindles were used, they may widen the front end trac. I would locate a reputable wheel shop, or a good buddy that has ordered wheels before, and make sure the measurements will work. No need to waste money on parts you can't run in the end.
Another note... I would lower the truck first and then order wheels. Just my $.02...
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
