Old 07-18-2009, 12:09 PM   #26
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Bolt choices
It's too hot for me to climb up in the shop loft and sort through my flywheels, but it seems that the pressure plate bolt holes in the flywheel have a slight bore into the flywheel before the threads start. That would give you leeway on the shoulder length somewhat.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-18-2009, 12:30 PM   #27
joe231
joe231's Avatar
Re: Bolt choices
Now that you mention it Kevin, I seem to remember that.
Green66, I was only saying if the smooth shoulder were too long it would bottom out in the threads before the clutch was tight.....
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-18-2009, 12:34 PM   #28
Green66Shortbed
Re: Bolt choices
now that i think about it a little more, i see what you are saying. it makes sense, but i think that the shoulder is the same size as the threads so all it would do is slide through. either way, i think im going to keep the bolts that i have. if i notice something wrong or hear it start to shake, ill fix it. lesson learned, lol. i cant help but think that as long as i have that little shoulder at the top of the bolt it wouldnt be any different. if it wants to come loose, its going to regardless of bolt choice, i think.
thanks for all the help, guys.
Green66Shortbed is offline   Reply With Quote
Old 07-18-2009, 12:50 PM   #29
joe231
joe231's Avatar
Re: Bolt choices
the shoulder should be the size of the blank (or slightly larger) before the threads were cut, so the bolt would bottom out at the shoulder.
I think your current bolts are probably good to go, assuming you torqued them properly
CHEVY ONLY
Old 07-18-2009, 01:07 PM   #30
hAetWagon
Schlongbed MEMBER (heh)#15
hAetWagon's Avatar
Re: Bolt choices
Merv Hall was a wise man.
82 Chevy Blazer 4wd.RIP
1965 Chevy C10,350V8
Get it reliable,then puttin' it in the weeds..
"Old truck, all new headaches."
hAetWagon is offline   Reply With Quote
Old 07-18-2009, 02:19 PM   #31
Green66Shortbed
Re: Bolt choices
45 lb. ft. sound correct?
