Old 07-19-2009, 03:11 PM   #26
bdydrp97s10
bdydrp97s10's Avatar
Re: What to expect from xmember chop.
any good fab shop around here charges around $55 dollars an hour..
i would guestimate probably 15-20 hours in this mod..
but XXL will have a better answer as far as how many hours are in it
My build thread--http://67-72chevytrucks.com/vboard/s...d.php?t=300333
bdydrp97s10 is offline   Reply With Quote
Old 07-19-2009, 03:14 PM   #27
Frizzle Fry
Frizzle Fry's Avatar
Originally Posted by smashingchuck View Post
Here's a pic of my steering. Everything is raised 1.5".
That's what I'm talkin 'bout
Frizzle Fry is offline   Reply With Quote
Old 07-20-2009, 11:51 PM   #28
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
if you are running 15" wheels the 3" drop spindles may be a problem
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 07-21-2009, 01:14 AM   #29
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Well I just reread some of this. What are people using for a rack and pinion? I think that would probably be the best option if you knew what you were doing.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-21-2009, 09:55 AM   #30
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
My stocks BARELY fit with my 3" spindles on...
AVS_JASON is offline   Reply With Quote
Old 07-28-2009, 05:29 PM   #31
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Missed this Whole thread. I have done all of these 1.5" and no one has complained about major clearance issues they were all as XXL pictured.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-28-2009, 09:04 PM   #32
jmedero
jmedero's Avatar
Smashing when you raised your suspen 1.5 was that done by raising the ster box?
Captkaos have you ever moved the xmember up to center the wheel? What am I looking at to do that. My question to be specific is can the member be moved forward and the motor mounts back so the engine, tranny all stays in the same location?
More info- wheels will be 29 inches tall
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 07-28-2009, 10:38 PM   #33
kev2809
low n' slo
kev2809's Avatar
hey captkaos, so even the 67-72 ones you did had no clearance issues? I want to do this mod when I get to bagging my 67 burb but really don't wanna move my steering up or doing anymore notching or cutting other than the 1.5" sectioning of the crossmember.
kev2809 is offline   Reply With Quote
Old 07-29-2009, 08:43 PM   #34
Frizzle Fry
If you don't move the steering up you will get bad bump-steer.
Old 08-04-2009, 05:31 PM   #35
Captkaos
Captkaos's Avatar
XXL's setup is the one I made for him, the clearance I have ran into on mine have only been what he showed.
jmedero, anything is possible with a welder and some steel.. It can be moved, but you would need to take in account the bolt hole locations and how far you want it moved. If I wanted it done, I would probably make mounting strip with the new locations drilled in them.
I still make these on occasionally, the cost is $585 + a core. I would not be interesting in moving the location forwards though.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 08-04-2009, 05:48 PM   #36
smashingchuck
I raised the box and the idler arm up 1.5 inches, then clearanced the frame until nothing hit from lock to lock. After that i built a new lower flange out of 1/4" steel. It's looks just like a c-notch from the inside of the frame.
78 Build Thread
4Runner Build
Old 08-04-2009, 09:44 PM   #37
Cooleys Custom Werx
urs is how mine is i just went 2 inches with everything and 1 inch forward to center the wheels. the problem i ran into was the steering shaft. but the fix to that is u joints. i have 2 1/2" drop spindles and 22's. i still had to pie cut my upper arms and step my lower arms. but this is what it took for my truck to lay out.
Cooleys Custom Werx is offline   Reply With Quote
Old 08-05-2009, 12:01 AM   #38
smashingchuck
Here's the best pic I have of how the steering shaft problem gets solved.
78 Build Thread
4Runner Build
Old 08-05-2009, 10:51 AM   #39
justpball
justpball's Avatar
seems like alot of work for 1-1.5 inches, does it really make that big of a diff?
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 08-05-2009, 11:04 AM   #40
smashingchuck
It's the difference between laying frame and laying your control arms on the ground and making the truck have a backwards rake when laid out. I'd say it makes all the difference.
78 Build Thread
4Runner Build
Old 08-05-2009, 11:17 AM   #41
SCOTI
SCOTI's Avatar
Even if you're not planning to lay out, it 's worth the effort. It allows that much more clearance @ a comparable ride height vs. not doing this type of mod.
I did my c.member exactly for this reason. I wanted more suspension & ground clearance but didn't wan't to have a higher ride height. Ultimately, I switched to a Dropmember for the additional clearance, improved geometry, & better track width.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-05-2009, 01:33 PM   #42
XXL
Seņor Member
XXL's Avatar
It's the Law of Diminishing Returns. In this case, the lower you go, the more work it takes to get less and less drop.
XXL is offline   Reply With Quote
