Old 07-19-2009, 08:43 PM   #1
50Bow-tied GMC
What is the best front suspension for a 1951 Chevy?
What is the best front suspension to use on a 1951 Chevy? I am wanting to put my truck on a 1968 frame, but running into a few issues with the steering box. I want to get some of the updates that are on a later model, but want to use the 1968 frame.
50Bow-tied GMC is offline   Reply With Quote
Old 07-20-2009, 11:13 AM   #2
mr48chev
mr48chev's Avatar
Re: What is the best front suspension for a 1951 Chevy?
I think it was covered before but that 68 frame/chassis just does not make a great swap in one of the trucks.
Sometimes you just have to get past the "I got it for free I'm gonna use it" syndrome and use something that really works to make a first class truck out of it. Not to say that it can't be done and drive ok but usually the wheels will stick out of the fenders too far and the truck will sit way too high for most guys who build custom trucks.
I'm not a big fan of sticking the S-10 chassis under the trucks but it is a far better choice to get a good looking and good driving truck out of the deal.
If you can't weld and don't mind spending the extra cash there are a couple of bolt on Mustang II cross members that only require a half inch electric drill, hand full of wrenches and tape measure to install.
I just got an email from Welder Series this morning http://www.welderseries.com/blog/200...eid=50aa7100c7 that says that Trucks TV is going to install one of their kits on a 49 on one of the early September shows. I'll have the dvr set for that as that is the unit I intend to use on my truck.
Old 07-20-2009, 12:29 PM   #3
robin58
I saw that episode of Trucks after they got the 49 and took it for a spin. I'm all for modifying 95% of the time, but the truck they acquired for this venture is in such great condition and so near 100% original and running it seems a shame to chop it all up. With all the less than perfect ones that are available it just makes me wonder why they're going that route. I'd have to think someone looking to run a 100% original truck would be happy to take it off their hands for a sum that would allow them to buy a multitude of less than perfect AD trucks.
Sorry for the hijack.
robin58 is offline   Reply With Quote
Old 07-20-2009, 12:41 PM   #4
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
I'd vote for the MII setup from one of the many vendors that offer them.
ChuckDriver is offline   Reply With Quote
Old 07-20-2009, 02:42 PM   #5
Atomsplitter
Atomsplitter's Avatar
Just make sure you don't cheap out and buy the MII IFS with the narrow (original style) lower a-arms that use the support struts. I have one in my truck and my turning radius is very wide because my tires hit the support struts.
Atomsplitter is offline   Reply With Quote
Old 07-20-2009, 04:09 PM   #6
steve53
steve53's Avatar
where did you get your mII IFS from? i would like to see some pics of what you mean.
53 Chevy 3100 1/2 ton
1st Armored Division, OIF Veteran
steve53 is offline   Reply With Quote
Old 07-20-2009, 07:32 PM   #7
Atomsplitter
I've been told that my truck has an early Fatman Fabrications MII IFS but I couldn't tell it from any other.
I went out to the garage and took a few pic's.
The first is from the rear and below,
Second is at the lower a-arm (the front anti-sway bar attaches with the same bolts as the strut rod).
Third is the attachment point of the bushing used to anchorand pivot the strut rod at the frame.
Old 07-20-2009, 07:34 PM   #8
Atomsplitter
Here's a pic from the front of the anti-sway bar to show how it attaches.
Old 07-20-2009, 07:55 PM   #9
ChuckDriver
Atomsplitter, I pretty sure your Older MII can be upgraded to the newer style lower control arms. If you think it's a Fatman give them a call and they can hook you up!
Old 07-21-2009, 09:09 AM   #10
robin58
Not to start a debate, but I think there are some serious considerations that anyone should give prior to eliminating that lower strut rod support. Ford put it there for a reason. There have been numerous documented failures of MII's with the eliminator style lower control arms. If you haven't yet done so, read up some at for example hotrodders (search for strut eliminator) about the potential issues. Personally I'd put up with a bigger turning circle.
Old 07-21-2009, 11:39 AM   #11
Kabwe
Certified Car Nut
Kabwe's Avatar
If you are concerned with this just completely box your cross member (the tubular a arms will mount on the outside of the cross member) and I also welded a bracket to my frame that will allow me to bolt the a arm to cross member and through the frame for extra safety. You can see my frame in my build thread. I've made some changes to the frame since that pic but that part is the same.
Kabwe is offline   Reply With Quote
Old 07-21-2009, 12:57 PM   #12
Atomsplitter
Robin58
Ribin58,
I'm cheap, therfore you are correct, I'll put up with the wider turning radius. I was giving some information to possible buyers of these cheaper MII IFS's. Unfortunately the vendors don't divulge issues like this as they want to sell their product. It would be nice if they did because then you would consider them to be honest and possibly pay the little but more and buy their tubular a-arm kit.
Kabwe
Kabwe,
Thanks for the information on the strut rod eliminators, I'll have to research this for the future.
Old 07-21-2009, 02:02 PM   #13
robin58
atomsplitter, you're right it would be nice if manufacturers divulged all potential issues. And as Kawbe points out there's more than one way to skin a cat. I just didn't want someone who was just reading to get the impression from one of the posts above that you could simply take that strutrod away without obviously putting stress somewhere else. Knowing you're doing so then at least would make a prudent driver routinely inspect the possible problem areas (something that imho could have prevented some of the failures documented for MII's).
Old 07-21-2009, 02:30 PM   #14
Kabwe
Certified Car Nut
Kabwe's Avatar
here are some better pics of what I'm talking about.
Old 07-21-2009, 07:28 PM   #15
Atomsplitter
Thanks Kabwe,
Great pictures!
So you cut out the end of the crossmember, drill the holes, installed and welded the tubes, rewelded the crossmember and welded in the support at the frame.
How do you keep this all in alignment with the other side of the IFS? It's not like the top that has all the adjustment to align the front end, these are fixed points?
Old 07-21-2009, 09:18 PM   #16
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
I used a Heights MII.
http://www.heidts.com/index.cfm/page...rod/prd125.htm
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 07-21-2009, 09:22 PM   #17
Kabwe
Certified Car Nut
Kabwe's Avatar
Thanks Kabwe,
Great pictures!
You don't have to cut the crossmember its already opened thats how your current lower a arms a installed. You open that hole that you current a arms are mounted on with a step drill to fit the tube. Don't weld nothing just mock everything with your new a arms and just tack it in place when you are sure everything is correct. Make strong tack welds so that nothing moves and take it apart and weld it all up.
Old 07-21-2009, 09:26 PM   #18
Kabwe
Certified Car Nut
Kabwe's Avatar
Originally Posted by BIG CHEVY 3600 View Post
He already has a crossmember he is just wanting to get rid of the struts and old a arms. Even with the new crossmember I still do that frame bracket for extra safety. Its just me I don't know if its needed but I feel better with it.lol
Old 07-21-2009, 11:52 PM   #19
Scottshotrods
you can go to www.scottshotrods.com
and you can see our ifs systems we offer we have
several members here that
have our ifs systems any
questions please ask
Justin
Scottshotrods is offline   Reply With Quote
Old 07-22-2009, 07:30 AM   #20
Atomsplitter
Thanks again Kabwe,
I think I'll start a separate thread dedicated to the strut rod eliminator question.
Scottshotrods
Justin
Does your company sell Strut Rod Eliminators? I had a look at the link you provided and I was wondering if you or your company have an opinion on the use of Strut Rods or was your post just to sell me a complete IFS?
Old 07-22-2009, 09:27 AM   #21
Scottshotrods
Thanks again Kabwe,
Scottshotrods
Yes we do have a lower a-arm kit you can purchase for your ifs you have now
that will remove your strut rod and give you the extra room you need.
Call us (805)485-0382
Thankyou,
Justin
Old 07-26-2009, 07:12 PM   #22
50Bow-tied GMC
Ok so if I were to use an S-10 frame is the any potential issues that I might encounter? What would be the best model years to use? I'm new to all of this, so I have a lot of questions.
Old 07-27-2009, 05:03 PM   #23
solidaxel
solidaxel's Avatar
Thankyou,
Justin
Justin,
Show us some pics of the before and after of your lower A-arm kits installed.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-28-2009, 01:48 PM   #24
Az. Hank
Az. Hank's Avatar
I,m going to use the Flat Out Engineering set up in my 58.
www.flatout-engineering.com
Az. Hank is offline   Reply With Quote
Old 07-28-2009, 06:02 PM   #25
jephs422
Originally Posted by solidaxel View Post
Justin,
I'll see if I have any installed pictures of the MII lower arm installed.
Jeff Savaglio
Scott's Hotrods
Oxnard CA 93030
jephs422 is offline   Reply With Quote
