Old 07-20-2009, 04:09 PM   #1
The Big Green
What pressure gauge setup?
Well, time for air pressure gauges, but which ones? I was going to use two 2in gauges, they are cheap, and easy I stalled. I have a switchbox, AVS 7, fbss setup. I was noticing the digital gauges, or the ones with two gauges and 4 swtches but it's not enough really. Under $300 for two dual needle gauges, or something that would work for me, what's out there. I'd rather spend $300 and under, but just depends. I want gauges but also need interior work lol.
The Big Green is offline   Reply With Quote
Old 07-20-2009, 05:06 PM   #2
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Re: What pressure gauge setup?
If you have a f.b.s.s. set up and the switch box already. You could just get two dual needle gauges and be good to go. You could even get a single needle one for the tank too if you would like. But no need to get a whole set up with switches if you already have them.
AVS_JASON is offline   Reply With Quote
Old 07-20-2009, 05:10 PM   #3
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Two of these
And one of these (bracket only)
Old 07-20-2009, 05:12 PM   #4
The Big Green
It would be the easiest route. I don't like my switchbox because it sits on my seat beside me but I have hit a switch before and I'm afraid I'll hit it going down the road. If I had somewhere it hang it or something then that would help. It's bounced of the seat before also, I tend to keep it in my right hand while turning but I have to air up to turn anyways.
Old 07-20-2009, 05:12 PM   #5
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Or one digital gauge like this will read all four corners and the tank
Old 07-20-2009, 05:13 PM   #6
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
You could send it in to us and I could install a "lock out" in it like our 9 switch boxes have.
Old 07-20-2009, 05:15 PM   #7
The Big Green
Hey, I like the blue ones in the cluster. That's the setup I first looked into so that's what I'll get.
Old 07-20-2009, 05:20 PM   #8
The Big Green
Quick question, the first ones use a 1/4 air line and the bottom post (digital) use wires and no air line? I like the idea of no line running thru the firewall, less chances of a air leak or failure.
Old 07-21-2009, 09:51 AM   #9
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Correct, the digital gauges use pressure sensors that send the reading to the gauge. Its all electrical, so no need for airline.
Old 07-21-2009, 10:59 AM   #10
The Big Green
It may be a lot more for digital but I like the idea of all the bags plus tank pressure in one gauge and no air line to break. I'd rather go digital, they just look cooler too. Thanks for the help Jason.
Old 07-25-2009, 12:36 PM   #11
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
I run a dakota digital pressure gauge and love it compared to my old 2 needles. Much easier to read at a glance and keeps the lines out of the cab.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
