04-01-2003, 09:46 PM | #1 |
truck won't start (no contact)
well i sat in the truck for a good 30 minutes trying to start it... this has happened to me once before...
when i turn the key, buzzer sounds as normal and all electrical stuff will operate. when i try to start it though... nothing... no sounds... nothing the engine doesn't turn over or anything. after turning the key a couple hundred times, when it finally gets contact it starts no probs. any idea what the problem could be??? |
04-01-2003, 09:55 PM | #2 |
Robert Olson Transport
Its hard to say but i would check the basics first corrosion on the battery terminals, loose wire or bad contact on the starter and id check the ignition switch could be the switch thing on the bottom of the column is either loose or worn out
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
04-01-2003, 09:59 PM | #3 |
Dr,
It could be several things but I would get a broomstick or any long stick and rap the solenoid with it the next time it won't start. If that does nothing then get a long screw driver or pry bar and ground the two terminals on the solenoid together. You should get a healthy spark when you do this and if you do and it still won't turn over its' starter time. If you get no spark, then it is ignition switch time. |
04-01-2003, 11:16 PM | #4 |
Does it have the ESC? I had a problem similar to this about 2 years ago. I fixed by by-passing the ESC. Have not had a problem since, except for the starter going out and the power steering pump, constant oil leak, etc....
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
04-01-2003, 11:32 PM | #5 |
When checking the corrosion on the cables..........also check the ground.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
