Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-23-2009, 09:57 AM   #26
71Dragtruck
71Dragtruck's Avatar
Re: bbc headers
Glad to see you finally got them in.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 07-23-2009, 09:16 PM   #27
69trk
69trk's Avatar
Re: bbc headers
Thanks, i take it that you ended up keeping your truck? You also have a nice project.
Originally Posted by ripdog28 View Post
Looks nice man. I doubt ill be spending that much on headers when time comes. Probly go with the regular hooker comp. love the truck man.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 07-23-2009, 09:18 PM   #28
69trk
69trk's Avatar
Re: bbc headers
thanks drag truck, especially for your help on picking a crossmember.. I ended up finding one almost just like yours thru trans dapt. Summit racing has them.
1.58- 60'
11.37- 1/4 @115.81
Old 07-29-2009, 01:03 PM   #29
frmula505
frmula505's Avatar
Re: bbc headers
Glad you finally got them in. I went with the same headers on my 59. I had to notch the outer shell on the drivers side motor mount (didn't change structurally), and grind on the a-fame a bit just for added clearance. Mine is a 427 CBB.
1961 GMC Suburban Custom
1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD)
1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746
1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD)
1951 Plymouth leadsled project
2005 Corvette conv. Procharged
1969 Corvette stingray
2006 Cadillac XLR-V
1950 Oldsmobile 98 custom project
frmula505 is offline   Reply With Quote
Old 08-10-2009, 04:53 PM   #30
69trk
69trk's Avatar
Re: bbc headers
new pictures of completed exhaust
1.58- 60'
11.37- 1/4 @115.81
Old 09-07-2009, 08:56 AM   #31
gene_ensor
gene_ensor's Avatar
Re: bbc headers
69trk - Thanks for the pictures. What size of pipe did you use to reinforce your cross member thru holes? Also, what size of exhaust are you running through your cross member? Thanks.
gene_ensor is offline   Reply With Quote
Old 09-09-2009, 09:40 PM   #32
69trk
69trk's Avatar
Re: bbc headers
I didn't weld anything in the holes. The pipe is 3" After the dumps.
1.58- 60'
11.37- 1/4 @115.81
Old 09-16-2009, 12:07 AM   #33
gene_ensor
gene_ensor's Avatar
Re: bbc headers
You might consider reinforcing your crossmember.
http://67-72chevytrucks.com/vboard/s....php?p=3250018
http://67-72chevytrucks.com/vboard/s...d.php?t=266474
http://67-72chevytrucks.com/vboard/s...d.php?t=318690
Old 09-16-2009, 06:36 AM   #34
69trk
69trk's Avatar
Re: bbc headers
i'm going to buy the ece crossmember. I was going to reinforce mine, until i seen a guy here at the track running low 10's for over 8 years and he never reinforced his. I do believe it's good insurance tho...I'll have my welding buddy come over and weld some flatstock on both sides this winter...
1.58- 60'
11.37- 1/4 @115.81
Old 09-22-2009, 06:28 PM   #35
ts71281
Re: bbc headers
Can you take a picture from the drivers side and show us where #7 primary comes down? I cannot find a header that will work with my big block zbar and bell crank. It keeps wanting to hit primary #7. I need a header that goes straight down there.
ts71281 is offline   Reply With Quote
Old 09-22-2009, 10:03 PM   #36
69trk
69trk's Avatar
Re: bbc headers
will this work? I don't have a very good picture of the number 7 primary. if not i'll get some other pictures when i get my truck back from the body shop.
1.58- 60'
11.37- 1/4 @115.81
