Old 07-23-2009, 10:22 PM   #1
truckincurt
aftermarket tilt colum
hi i got a 1978 and i put a 700r4 in it a 4 speed trans ... was wonderin if anyone knew where i could get a aftermarket sterring colum that would have (P.R.N.D.3.2.1) and mabey chrome lol thanks for your help
diy or die
truckincurt is offline   Reply With Quote
Old 07-24-2009, 12:03 AM   #2
kevinr1970
Re: aftermarket tilt colum
The PRND321 is part of the dash. I *think* that if your existing column goes through the entire range than all you need is the part of the dash with the indicator.
I *think*?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 07-24-2009, 12:07 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
the indicator mounts to the gauge cluster
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 07-24-2009, 01:26 AM   #4
3r!c84
Badass
3r!c84's Avatar
and the colum shifter has a string that runs to the shifter indicater so just change out the number plate and youll be
good
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 07-24-2009, 02:00 AM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I'm sure Ididit or Flaming River would have what you're looking for. Just black out the one in the dash.
http://www.summitracing.com/parts/IDT-1520690020/
http://www.summitracing.com/parts/FLA-FR20022PL/
http://www.summitracing.com/parts/IDT-2600050010/
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 07-24-2009, 02:09 AM   #6
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
here ya go!
http://67-72chevytrucks.com/vboard/s...ight=indicator
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 07-24-2009, 11:20 AM   #7
truckincurt
thanks smashingchuck ididit is perfect thanks alot
diy or die
Old 07-24-2009, 11:33 AM   #8
smashingchuck
I think I would just call them directly and tell them what you have and what you want to do. They should be able to set you right up with a drop in unit. Their web site is:
www.ididit.com
78 Build Thread
4Runner Build
Old 07-24-2009, 01:21 PM   #9
3r!c84
Badass
3r!c84's Avatar
thats the same kind of colum as a 72 c10
-00 Saturn 5spd
1/4:13:90
colum
