Old 07-24-2009, 01:31 PM   #1
72WHITELIGHTNING
Please help, with drilled,slotted rotors 4 & 3/4 bolt pattern
Looking for info on a place I can buy drilled,slotted rotors for my 1972 C10 2wd swb. The catch is,they have to have 5 by 4 3/4 bolt pattern,NOT 5 by 5. Please anyone with info would be greatly appreciated. Thanks
72WHITELIGHTNING is offline   Reply With Quote
Old 07-24-2009, 01:50 PM   #2
SCOTI
SCOTI's Avatar
Re: Please help, with drilled,slotted rotors 4 & 3/4 bolt pattern
I don't know of a manufacturer that sells direct swap 5x5 bearing spec'd cross-drilled rotor in a 5x4.75 pattern. You could get some drilled/slotted truck rotors & have the lug pattern redrilled to the car pattern.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-24-2009, 02:16 PM   #3
fine69
fine69's Avatar
Actually you can not do this. The center hub on truck rotors is huge compared to the car. And it wont fit into most small pattern GM wheels.
You can buy a disc brake conversion kit for your stock spindles though.
I have done it.
Actually i bought my kit from Classic Parts of America (when it was still Chevy Duty).
Here is a link,
http://www.classicparts.com/1964-70-...ctinfo/71-977/
Very easy to install.
Crap, just noticed that you have a 72. This info might not help you. But check out their site. Might find something.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 07-24-2009, 02:22 PM   #4
mclairmo
I would think CPP or POL would have them or knows who does.
mclairmo is offline   Reply With Quote
Old 07-24-2009, 03:56 PM   #5
SCOTI
SCOTI's Avatar
You can do this very thing. I have a set of 5x5 1.25" truck rotors that have been machined to work w/car wheels. The bolt pattern is easily re-drilled & the snout is machined down very slightly to fit within the car wheel hub pilot-hole. Cost me about $100 for both rotors....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
