Old 07-24-2009, 11:55 PM   #1
hemihead
hemihead's Avatar
Saginaw Type PS pumps
I have a few questions about these pumps.
How can I tell if I have a press fit or keyed pump?
Can I adapt one that was on a SBC to a BBC with only a bracket change?
If I have a press fit how do I get the pulley off?
Thanks for any input and pics are appreciated!
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
Old 07-25-2009, 06:41 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Saginaw Type PS pumps
The keyed pump will have the center shaft with threads sticking past the pulley with a nut on it.
The pressed type will have the pump shaft flush with the edge of the pulley with no nut retaining the pulley.
You need a pulley puller to get the pressed pulley off.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 07-25-2009, 09:23 AM   #3
mbgmike
Here is the press on type sorry don't have the bolt on pic
mbgmike is offline   Reply With Quote
Old 08-13-2009, 05:44 PM   #4
hemihead
hemihead's Avatar
I have thistype of pump off a sbc, will it fit a bbc just by changing the brackets.
2009 Acura MDX
Old 08-13-2009, 06:55 PM   #5
turp mcspray
turp mcspray's Avatar
You didn't say what you are working on. (truck i'm guessing) long water pump or short water pump. Fwiw I recently finished a 67 camaro with a bb. It had the older "round" looking pump/reservoir combo. Looks like the ones used on these older trucks. The pump was from a small block and was used on the bb with a different bracket. However the camaro has the pump/reservoir combo bolted to the engine for all applications. Unlike the truck and chevelle which used a separate pump and reservoir on the bb.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 08-13-2009, 11:14 PM   #6
BCOWANWHEELS
A bolt on pulley is alot more user friendly.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
