Old 07-26-2009, 07:57 PM   #1
kcackler
How the F* does the steering wheel go back together?
OK, so I finally got around to putting in my new used steering wheel tonight but I'm having some serious problems with the horn. When I was taking the old wheel off, the horn plunger popped out of the wheel, along with (I think) a small nut looking thing. Though with all of the crap in my floor, I'm not sure that nut looking thing came out of the wheel.
So I'm trying to fit the horn components back together and I'm running into a heck of a time. Here's how I THINK it goes back together:
Spring sits in green sleeve.
Plunger sits, head down, on top of spring
Flat metal ring sits inside steering wheel and holds plunger on top of spring
Deep metal ring fits on top of that and screws into wheel
Center cap sits on top of that
The problem is that the goes off non stop when I put it together like that. Am I missing a piece or am I just trying to put it together the wrong way?
Tips or pictures are appreciated here...
Blue - 77 Chevy Scottsdale
kcackler is offline   Reply With Quote
Old 07-26-2009, 08:07 PM   #2
74 C-30
Dually Pride
74 C-30's Avatar
Re: How the F* does the steering wheel go back together?
i dunno if it helps any but he's what LMC shows as a picture
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=138
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 07-26-2009, 08:15 PM   #3
kcackler
Thanks. That diagrams looks like the plunger goes head down into the sleeve, then the spring on top of that and then a button of some sort on top of that. But that doesn't make sense to me since when I took the wheel apart the plunger flew out and the spring stayed in the sleeve...so it couldn't have been put together like that.
Anyone with first hand experience with this here?
Old 07-27-2009, 10:11 AM   #4
Igotachevyor2
Apache Club
Igotachevyor2's Avatar
check out this link
58 CHEVY APACHE I 74 CHEVY C-10 I 78 K-10 donor truck I 89 SONOMA
My Trucks Apache Sitting Idle MySpace
Project Dad's Truck (74 C-10 to K-10 conversion)
Igotachevyor2 is offline   Reply With Quote
Old 07-27-2009, 10:15 AM   #5
kcackler
Those internals are completely different than mine. I have no wire in mine.
Thanks for the link, but I'm still stuck here. Going to look at my brother's 86 today and see if it's totally different...
Old 07-28-2009, 01:45 PM   #6
kcackler
Still curious as to how this goes back together. I found http://www.classicparts.com/1973-89-...ctinfo/27-227/ which shows a little black piece that I can't find anywhere, which means I've probably lost it. So I ordered a new contact kit but I still don't know how I'm going to put it back together once I get it.
Old 07-28-2009, 05:44 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
This help? It is a teardown all the way to the tilt joint that I did on my truck.
http://forum.73-87chevytrucks.com/sm...?topic=12525.0
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 07-28-2009, 06:10 PM   #8
kcackler
That did help. Looking at your pictures, it seems like I may be missing part of the pin/spring assembly, which is what's throwing me off. Hopefully when it gets here I'll be able to piece it back together.
Old 02-20-2014, 06:48 PM   #9
Ronald29609
Help please. I swapped a '72 automatic tilt column for the '67 standard column that was in the '67 truck. The '67 wheel doesn't seem to fit. There's a gap between the turn signal hub and the wheel. Am I doing something wrong?
Ronald29609 is offline   Reply With Quote
