07-27-2009, 07:53 PM | #1 |
PROJECT 7DEUCE
Fat mat who has it....
Who has this installed on there ride I know I should have asked before I bought it but....... I know I have heard people on here rave about please chim in guys and let me know the secrets of the install if there are any...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
07-27-2009, 08:13 PM | #2 |
What?
Re: Fat mat who has it....
I just put in Dynamat on the floor of my burb, they are pretty close in comparison I think.
Trick is to do it on a hot sunny day, it will make it more flexible to form. I plan on installing more of the stuff, but it is so expensive I can only afford to do a section at a time.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
07-27-2009, 08:21 PM | #3 |
PROJECT 7DEUCE
110 sq feet of fat mat cot me 130 shipped.... And Its 102 here today sooooo it should be pretty flexable..
07-27-2009, 11:30 PM | #4 |
PROJECT 7DEUCE
t.t.t.
07-27-2009, 11:47 PM | #5 |
I have used it in a couple of installs. It works great on the floors but on a vertical suface if does stick so great. I could be because it was not cleaned good enough i did clean the panel. I would buy it again.
07-28-2009, 12:19 PM | #6 |
I used it on my cab floor and it worked great. Probably would have even gone on even easier if I didn't do it when the garage was 50 degrees, but it went on fine.
07-28-2009, 12:56 PM | #7 |
Wide n'Low
I used it on my square body as well, worked fine and went on really easy.
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
07-28-2009, 01:16 PM | #8 |
"GO DAWGS"
I put Fat mat in my 94 swb and it is not that hard at all. The key is to spend your time getting the surface as clean as possible. It killed alot of road noise.
PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
01-29-2014, 01:00 PM | #9 |
Can FatMat or DynaMat be used under the hood?? Would it help reduce noise?
Sorry for resurrecting an old post.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
01-29-2014, 02:01 PM | #10 |
I think they both sell stuff specifically for the engine compartment.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-29-2014, 06:04 PM | #11 |
I used it on the floor and sides of my Blazer before installing carpet and side panels. Very easy to install and really reduced road/exhaust noise. I don't think it would work well in the engine compartment. When it gets warm/hot the tar backing gets soft and it may peel off the underside of your hood under its own weight. There are other products for the engine compartment.
01-29-2014, 06:13 PM | #12 |
My boys did the entire cab and doors with fat mat, easy to use, great product and price!
Scotts72C10 |
01-29-2014, 06:25 PM | #13 |
I put in the interior and under the hood. However, I've only driven it a couple short trips, but it seems to be quieter. I'm happy with it.
1970 C10 Short Stepper with 71/72 front clip. |
01-29-2014, 08:52 PM | #14 |
I used it on my floors and doors of my Challenger. Someone on the mopar board told me that he installed it on his roof and in the heat it came unglued and fell onto his headliner. If it isn't warm where you are, then use a small heater in the cab to warm the mat and a hairdryer when rolling it on the floorboards
01-29-2014, 09:35 PM | #15 | |
01-29-2014, 09:50 PM | #16 | |
