Old 07-28-2009, 06:50 PM   #1
Can-O-Worms
Just picked up a '69
I picked up this '69 this weekend. It's in pretty good shape, with the rust in the usual places and a few electrical issues. I did have to replace the p.s. pump, but now there is alot of air in the system. Anyone have a suggestion for removing the air, I have'nt done alot of p.s. work.
Can-O-Worms is offline   Reply With Quote
Old 07-28-2009, 06:57 PM   #2
cerjio
Re: Just picked up a '69
turn you steering wheel all the way one way then rotate it the oppsite way an repeat sevearl times
cerjio is offline   Reply With Quote
Old 07-28-2009, 07:03 PM   #3
sson20s
sson20s's Avatar
nice truck , good luck
2 many ,want to finish 1
sson20s is offline   Reply With Quote
Old 07-28-2009, 07:49 PM   #4
sjarrett71
sjarrett71's Avatar
Jack the wheels up first so there is less resistance then go stop to stop. Make sure you don't run out of fluid.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 07-28-2009, 09:31 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Looks like a '71, to me (grille/5-lugs/rearview mirror). I am guessing that you matched the title to the VIN on the cab. Looks pretty straight. Good find.
Member Nr. 2770
Old 07-28-2009, 10:00 PM   #6
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Lightbulb Re: Just picked up a '69
I was about to say the same thing.
As it does not look like any '69 I have ever seen.
Nice truck in any case.
Congrats!
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 07-28-2009, 10:30 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
they don't use titles there, so the seller was probably confused. Does the VIN start with CE141xxxxxxx or maybe CS141xxxxxx?
welcome to the board from central ohio.
Looks like a decent 'ole truck. Whats the plans?
On the power steering deal, since you started from dry, here's the steps we took at work when we were rebuilding the P/30 trycks. (same steering system you have)
fill full of fluid
jack up front end
With the engine not running turn wheel SLOWLY from full left to full right a few times
walk away for a half hr
Lock to lock a few times again (engine still off) and walk away for a half hr.
lower truck, check fluid level. if low, bring it to a little over full. If a little over, then leave it alone, if way overfull, suck some out with a turky bastor from the kitchen. (you own that now)
Fire up engine, and at an idle, and on the ground, turn from lock to lock holding the wheel against the lock for about a second on each stop. If it is groaning and making all kinds of noise, then shut it off anf let it sit. If it did it fairly quiet, then crank it back and forth again.
Once it feels right and sounds right, then set your fluid level at full cold and then drive it and check it again, and top it off to full hot.
Yes, this is a little long and drawn out, but it works great, and hardly any foaming of the fluid is formed, which can take quite a while to bleed out when you pump foam (air) to the gear box.
Old 07-29-2009, 09:44 AM   #8
Can-O-Worms
Thanks for the advice, I'll give it a try. The VIN starts with CE141 and if I read it right, according to the chart in the Classic Parts catalog it's a '69. I will check it again to make sure. I'm new to the site and also new to these trucks, although a long-time fan, so I'm definately learning. I'm sure I'll need more help and pointers as I go along.
Old 07-29-2009, 09:46 AM   #9
VanceH
Loving the Jimmster
VanceH's Avatar
very nice
VanceH is offline   Reply With Quote
Old 07-29-2009, 01:27 PM   #10
john
member #16
john's Avatar
Heres a decoder. Welcome to the board, nice truck.
http://67-72chevytrucks.com/Chevyear.html
john is offline   Reply With Quote
Old 07-29-2009, 04:53 PM   #11
Can-O-Worms
I double checked the VIN and it is CE149..., so I guess it is a 1969 model with a later grill. I don't know anything about what the 5 lug on the rear means, but it has had a disc brake install done on the front. Appreciate the help.
Old 07-29-2009, 05:50 PM   #12
cerjio
wow if somebody already did the Disc brake conversion for you, your Lucky, but nice truck even if its a 69
Old 07-29-2009, 06:02 PM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Yeah, if the disc brake conversion is already done, you lucked out. Just count your blessings and rejoice!
Member Nr. 2770
Old 07-29-2009, 09:05 PM   #14
Boog
laying low
Boog's Avatar
Details dude. Details...
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
