Old 07-28-2009, 01:19 PM   #1
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
72 Super part-out (feeler ad)
Debating parting out my project to pursue other things and spend more time with the family. None of this stuff is officially for sale unless I can generate enough interest to basically sell everything. Here is what I have...
A/C cab, perfect floor and supports, very minor rust in rocker, a-pillar area.
Over all very solid. Will need some normal repairs. Comes with clear title and vin tag. $300 picked up.
Forgot to add, rust free, nearly perfect 72 doors. Complete. $300 for the pair.
Shortbed chassis, blasted and Por-15 painted. Everything rebuilt. All new cross shafts, ball joints, rotors, calipers, you name it. Everything is ready to go. ECE 2 1/2 spindles and 2 inch drop small block springs. 6 inch drop springs in the rear. Adjustable super trac bar, rebuilt diff, 3.73 gears and a rebuilt posi. All new clutches, bearings, seals, etc. Impals SS rear discs, cross drilled rotors front and rear. All 4 new calipers and cross drilled rotors, stainless brake lines, 73-87 style engine mounts. Front sway bar with poly bushings, 8 inch Truck ralley rollers, etc, etc, etc.
$1500 picked up.
.030 over 1975 454 long block. Keith Black dome pistons, Lunati 60202 cam, 781 heads fully rebuilt, all machine work done on engine and heads. Comp Cams Roller rockers and pushrods. Comp timing chain set. Have receipts for all work. This was not just pieced together. This is an assembled long block minus the roller rockers. They're still in the box. Comes with oil pan and turbo 400 flywheel. $1500 Picked up.
New in package cab and core support mount kit. $100 shipped in lower 48.
Rust free 69-72 core support. $100 picked up.
Truck tilt column. This is not a van column. Tilt unit is tight. Just needs a new turn signal switch because one wire was messed up. $300 plus shipping.
Re-pop delux marker lights. Have front and rear as well as taillight lenses and backup light lenses. One backup light lens has a chip on corner. Dont think it will be seen once installed. $100 shipped for all.
4 rear wheel tubs, Not rusted. $40 per set.
Front panel for wood bed. Nearly perfect. No rust. $80
Rear panel for wood bed. OK condition, no rust. Will throw in with front panel if interested.
Woodgrain aluminum 72 door panel inserts with trim pieces. The trim is not reproduced and these are very nice. $60 for all 4 pieces.
I know I am missing some stuff and I will post later what I find. I will not start parting this stuff out unless the chassis and cab get sold first.
Please let me know if you need pics. We know what most of this stuff looks like. Thanks alot.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 07-28-2009, 01:52 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 72 Super part-out (feeler ad)
You've assembled a great collection of parts, but I know where you're coming from. It's really easy to get consumed by these projects. My suggestion would be to stick it in the garage and lock the door. Open it back up when you feel you've achieved the balance you're looking for. Best of luck and take care..
Hart_Rod is offline   Reply With Quote
Old 07-28-2009, 01:57 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I would be interested in those woodgrain Door panels providing pics. Also, if you have a woodgrain dash bezel and woodgrain super glovebox door, I would be interested in them as well. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 07-28-2009, 04:01 PM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
So is the engine ready to go in??...what else does it need??
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 07-28-2009, 04:06 PM   #5
liftmeup
doors need pics inside, out side lower corners,seams ,hinge area also thanks
liftmeup is offline   Reply With Quote
Old 07-28-2009, 07:44 PM   #6
STOCKISH
STOCKISH's Avatar
Engine needs intake, carb, distributor, accessories, etc.
--Josh
Old 07-28-2009, 07:45 PM   #7
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
I would be interested in the door panels as well...also depending on shipping I would be interested in the chassis and the wood bed panels too....pics would be appreciated.
thanks, Ron
-Ron-
OldSkool71 is offline   Reply With Quote
Old 07-28-2009, 07:48 PM   #8
STOCKISH
STOCKISH's Avatar
Everything is packed in the garage right now and I cant get to them at this moment. You will not find any rust on these doors ANYWHERE. I looked them over probably 10 times each. Hinge mounting area is perfect, bottom corners are perfect, only issue is someone cut a 4 inch or so hole for speakers. NO RUST ANYWHERE PERIOD. If someone buys the cab they have first shot at the doors. If they do not want them you will be first in line and I will try to get pics later if still needed.
--Josh
Old 07-28-2009, 07:51 PM   #9
STOCKISH
STOCKISH's Avatar
thanks, Ron
The panels you speak of are the inserts for the Cheyenne Super, not the whole door panel. you'll be 2nd in line if 71blksuper4x4 passes. I will try to get pics tonight for you guys. I will ship the chassis if you set everything up. My zip is 27587 if you want to get an estimate.
--Josh
Old 07-28-2009, 08:04 PM   #10
mac72
What year is the cab?
mac72 is offline   Reply With Quote
Old 07-28-2009, 08:09 PM   #11
STOCKISH
STOCKISH's Avatar
The cab is a 72. Looks like the sale might be on hold for a while. My wife asked why I was trying to upload pics so I told her. Well, that didn't sit too well. Apparently, someone may or may not be buying me the 20 and 22 inch Foose nitrous wheels I've been wanting for my b-day. I guess everybody got together and pitched in. I would hate to piss everyone off if they bought me some Foose wheels and I had no truck to put them on. I am sorry but I will keep you guys updated. I am sure you guys can understand though. Thanks
--Josh
Old 07-28-2009, 08:59 PM   #12
david wiebelt
If anything changes I would be interested in the tilt wheel. Good luck.
david wiebelt is offline   Reply With Quote
Old 07-28-2009, 09:36 PM   #13
71SWBChevy
71SWBChevy's Avatar
I would be interested in the doors if I haven't found a set by the time you decide to part it out.
Drew
'71 Chevy 350/TH350 Hugger Orange
Currently just a rolling frame, body work soon to follow!!!
Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=212927
Daily Driver: 1997 Chevrolet S-10 with more gears than pistons
71SWBChevy is offline   Reply With Quote
Old 07-28-2009, 09:41 PM   #14
jsmithbm
jsmithbm's Avatar
Thats what i am talking about right there! Sounds like you have a great family behind YOU for sure
Learning as I go!
jsmithbm is offline   Reply With Quote
Old 07-28-2009, 10:14 PM   #15
2000tj
If you decide to part it out, I would like to buy the cab and doors. I live in Asheville, NC and can pick them up. Thanks, Scott
2000tj is offline   Reply With Quote
