07-31-2009, 09:01 AM | #1 |
Mejor Que Nada
Need help spending $4500 on 69 step
I have already finished the brakes, updated to power front discs. Replaced all stainless brake lines and hoses. Rebuilt front suspension. What the truck needs is engine, transmission, and A/c. 350 is tired loses oil pressure after warm up pretty severely. Trans is th400 with leaks everywhere. In the texas heat it needs a/c. It is a factory a/c cab but all components are missing.
Don't know if I should either add new crate motor or rebuild this 350. I would like a overdrive transmission but this would mean different drive shaft different shifter and add more to the build. I could possibly just ditch the 4:10 gears and go with a 3:42 or even 3:08. What do you think? Then where would be the best place to get the A/C kit from and which kit is better? I need to get this thing on the road, I am without a second vehicle right now. The wife's Tahoe is all we have currently other than my company truck.
The only thing that separates "Dreams" from "Reality" is TIME and MONEY!!! Last edited by casterbuster; 07-31-2009 at 09:03 AM. |
07-31-2009, 09:19 AM | #2 |
69 K20
Re: Need help spending $4500 on 69 step
If it were me I would sink some dough into the a/c, especially you being it Texas, and go with a used engine and tranny. If you really need it for you second vehicle that is. You could always upgrade the engine/tranny later on down the road if you wanted to but at least it would be on the road. I would like to hear some feedback on the different aftermarket a/c options. I will be doing that to mine eventually.
07-31-2009, 09:26 AM | #3 |
Mejor Que Nada
I want to do all three things with this money. I am just looking for my best options.
The only thing that separates "Dreams" from "Reality" is TIME and MONEY!!! |
07-31-2009, 09:30 AM | #4 |
Between Trucks...
Vintage Air - $1200
GM Crate 260 HP - $1400 New TH 400 - $750?
Beat it to fit, Paint it to match... |
07-31-2009, 09:34 AM | #5 |
Mejor Que Nada
Where did these prices come from, now i am intrigued. $750 for th400, and the engine where?
07-31-2009, 09:41 AM | #6 |
Champagne Taste on Beer Budget
For the A/C I would go with http://www.vintageair.com/index.asp this is the one I will go with when I decide to add A/C to my '67.
But as far as engine and tranny that's a tough choice. Rebuilting your 350 would probably be the best bang for your buck since you want to replace your transmisison as well. Find a good rebuild shop and have them customize the engine for how you are going to use your truck. Good luck and keep us updated!
Coming Soon: Project 1970 Country Truck |
07-31-2009, 09:55 AM | #7 |
Between Trucks...
Prices are actually a little more. I'm pretty sure the GM Crate motor is rated higher then listed. Just some ideas, shop around.
See what you can dig up locally. http://www.summitracing.com/parts/SUM-700400/ http://www.summitracing.com/parts/NAL-10067353/
07-31-2009, 10:10 AM | #8 |
motor exploder
here's the 290hp version...
http://www.summitracing.com/parts/NAL-12499529/ my dad put one in his '84 Heavy Half LWB with a set of 1 5/8's hedman headers and a Q-Jet and it runs very nice - smooth spread of power and no issues, plus you get a warranty. On the gear swap, a professionally set up rear gear swap will cost about as much as swapping in a 700R4 (+/- $1200), just depends on your preference. If you already need a trans, and you decide to swap gears, you're looking at rebuilding the TH400 AND swapping gears. You could just to the OD tranny and leave the rearend alone, plus the low 1st gear in the 700R4 and those 4.10's would be fun with a fresh motor! Wish I could help on the a/c. My '69 is an a/c truck, but it doesn't work and I just have to sweat it out for now!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
07-31-2009, 10:14 AM | #9 |
for the engine/trans,I would search through the classifieds in your area and try to find a used car,like a mid 80's Caprice/Impala with maybe under 100000 miles that is currently running .That way you could hear it run and drive it and check it out. Should have an o/d trans,plus you would get all the brackets and a/c parts you would need,along with a lot of smaller parts you could use(like maybe cruise control).When I bought my truck,the previous owner also had an 87 Caprice his father had wrecked that was in excellent running condition with a 305/700R4 trans. I wish I would have bought it and transplanted the drive train into my truck
07-31-2009, 10:32 AM | #10 | |
Mejor Que Nada
07-31-2009, 10:40 AM | #11 |
motor exploder
and lose the warranty...
07-31-2009, 10:51 AM | #12 |
Mejor Que Nada
If you read the fine print the warranty is only good if the engine is installed by a professional shop. Besides i am a mechanic just not an auto mechanic.
Warranties in my line of work are just a piece of paper the manufacturer throws in the box so you can wipe your butt if you run out of TP, and you can quote me on that. There are so many loop holes to get out of warranties it is not even funny.
07-31-2009, 11:02 AM | #13 |
motor exploder
I understand that, just saying.
07-31-2009, 11:06 AM | #14 |
resident oilfield trash
290 HP GM 4bolt 350 1600 http://www.sdparts.com/product/10067...350Engine.aspx
Rebuilt 700 R 4 850 You can get factory AC for around 500 for everything
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada Last edited by jbristo67; 07-31-2009 at 11:09 AM. |
07-31-2009, 11:36 AM | #15 |
Mejor Que Nada
what about old air from gmcpauls he has is listed under $1000
07-31-2009, 11:39 AM | #16 |
i got have a idea paypal it too brad.m.good@us.army.mi i will be looking for it in the next day or too
07-31-2009, 11:43 AM | #17 |
I'm not a big fan of that 290HP cam. And it certainly isn't worth $400.
Sounds like you should do a LSx swap.. 5.3? 6.0? |
07-31-2009, 11:47 AM | #18 | |
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
07-31-2009, 11:48 AM | #19 |
Mejor Que Nada
How would I ever afford that on 4500 budget. Now, your talking fuel tank, wiring harness, programming, fuel pump, engine and transmission, exhaust, and I am sure I am forgetting a lot. I wish but it doesn't sound doable, unless you know something I don't.
07-31-2009, 11:49 AM | #20 |
I agree with Sinister 100%. The 260 crate from GM is all you need for around town and it will be reliable. I will likely go with that engine when the need arises. Rebuilt might be cheaper but unless you know the rebuilder real well, it could just be a waste of your money. Plus, you may have to pay for shipping. With the GM crate, the dealer should be able to get it for no addl cost. Also, GM should be able to warranty the engine or least help you out more than a rebuilder might. A rebuilt TH400 and convertor from a local rebuilder should be about that much or even less. Vintage Air will be more reliable than the factory a/c and may end up easier to install than trying to piece together a factory system. Go with basic and simple parts and you should be able to make it within your budget. However, don't go with used stuff unless it is something like wheels or valve covers since you want to only have to do this once and have it be correct and reliable.
07-31-2009, 11:53 AM | #21 | |
Mejor Que Nada
07-31-2009, 11:54 AM | #22 |
Should be able to get the engine/trans for about $2000-2500.
07-31-2009, 12:00 PM | #23 |
Between Trucks...
He wants a motor/tranny and A/C for the $4500.
Beat it to fit, Paint it to match... Last edited by Sinister; 07-31-2009 at 12:00 PM. |
07-31-2009, 12:02 PM | #24 |
check out the link in my sig.
$2k for motor and trans with 16k miles on it. (this being stated b/c you can get a 6.0/6l80 for cheaper and the 5.3/4l60es are even cheaper) $535 for the headers $500 in misc stuff like fuel pump/filter/hose/cooler/etc $300ish is expected for the rest of the exhaust and then there is the DS i assume is going to be $150 or less.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
07-31-2009, 12:10 PM | #25 | |
